I am pushing 87db speakers that have hybrid Lattice tweeter and go from 32 Hz to 40 kHz with 6 Ohms average 3.2 Ohms minimum.
I had JL F112v with CR1 Crossover. I simply could not get the subs dialed in. I called JL audio, you would need a PHD from NASA to get these subs to dial in. I gave up and am disconnected them. Running speakers full range and things sound more clear for sure.
I am contemplating buying the Rel Carbons.
Question: Some experts say (i) Dont use subs you are adding complexity and getting in the way of the spekears (ii) add subs for soundstage and it will open up speakers with less stress. Crossover at 50hz, 60hz, no do it at 30hz with low gain. No add more gain.
To boot, there are almost no experts that actually no how to work the crossover and the JL subs. Their implied marketshare for 2 channel must be half of rel given the lack of expertise.
Experts also say "no one uses JLaudio for 2 channel its just for movies, they are too slow. Need Rel."
I am under the impression that 9/10 times the best sounding rooms at shows do not use subs. If this is incorrect would want to know. Theoretically if dealers are trying to sell their gear they would have an incentive to pull out all the stops to make the room sound as good as possible.
I am dealing with 19x11x9 foot room.
So, to sub or not to sub, that is the question.
