Here’s a few thoughts on Tripoint Troy Elite NG...
Although you can place any Tripoint Troy wherever you want these devices do benefit if you pay a proper attention to isolation. I tried various platforms under my ex Troy Signature and differences were clearly audible. Haven’t experimented with isolation platforms under the Elite NG yet, but I have changed spike bases and heard a clear improvement in the bass that became tighter and more defined. If such a minor change was audible, you can imagine the impact of a high quality isolation base. A very thick and heavy ebony platform is in the works and will report on this later.
Troy Elite NG showed its potential the moment I connected the Emperor power cable to the wall socket (this was before I bought Cardas Nautilus). Even without connecting any grounding cable this alone brought better bass articulation, soundstage expansion, and more focus with a subtle feeling of calmness. This was a big surprise, and I was wondering why that happened? How can this influence the sound of the system? Thought it had something to do with the EMI/RFI, so I tried AlphaLab Inc. EMI Line Meter but readings didn’t show anything conclusive.
Then both Emperors Mkii and Silver Signatures went in and after a few hours three things were immediately obvious: bass became a bit stronger, and deeper, soundstage expanded a bit more, and there was a clear improvement in dynamics and speed. As Audiocrack and Dave explained in their reports, Emperor Mkii needs at least 400 hours of burn-in. After a few days of excitement and enjoyment, the expected “down phase” came. Miguel also warned me about the crazy way these grounding cables behave in the burn-in period, but I was not expecting such huge swings between “good and bad periods”. Anyway, after three months cables obviously settled as the sound became consistent.
Unfortunately I haven’t heard the regular Elite to make direct comparison but did own the Signature for several years and can say this: Even if you know the effects of Troy Signature (with or without the Thor SE grounding cables), that can not prepare you for a huge jump in realism the Elite NG/Emperor Mkii combo brings to the table. There is simply no comparison. Some improvements on which the Signature only hinted at are fully developed with the Elite NG (like bass, solidity, soundstage, clarity, and articulation), and then lifted to a far, far higher level, but there are also totally new improvements.
With this combo, there is no highlighting of any frequency at any time. Midrange is seamlessly connected with the treble and everything is more fluid, more natural (unprocessed) with a beautiful sense of completeness. Next thing I noticed and find it interesting is increased serenity between notes, a new sense of calmness and natural easiness.
A minor “complaint” about the sound of otherwise superb conrad-johnson ART mono blocks I have is their ability to articulate starting transients. My previous power amps were solid state Karan KAM 2000 which excelled in transients articulation but adding a new Tripoint grounding system brought this quality with the cj ART on a solid state level. Unbelievable.
Next thing was the truth of timbres. Improved articulation, and clarity can result in improved timbres, but with the Tripoint combo there was also more weight, density, and solidity to instruments. This infusion of weight to bodies of instruments (without softening!), was also present in lower most registers, but the clarity and articulation of each string draw, pluck, or air blow also improved tremendously.
Musical presentation became much more dynamic, agile, and explosive. The sense of speed and agility is incredible and reminds me of a great horn system. Soundstage became not only much deeper, wider, and better defined. More important to me is a rock solid 3D presentation of instruments and their proportional dimensions. I heard this “effect” for the first time in Hong Kong a few years ago and I think it is an important contributor of the feeling “being in their presence” and (IMO) a result of fewer artifacts and less distortion.
My system always sounded best from 9 am to 4 pm and then late at night, at other times the sound could be often boring, but with the Elite NG/Emperor Mkii these differences simply vanished. System now sounds great no matter when I listen. I’m not sure this effect would be heard in every system but in mine, this combo also acts like a completely invisible power line filter. This is like a dream come true. System performing optimally no matter when you listen to it! Crazy.
One more thing. Everything I have described above is easily heard also at very low volumes. Especially airier and expanded soundstage, denser colors and fuller bodies of instruments stand out.
Years ago I bought Troy Signature blind. I simply couldn’t have imagined that every review and report from users (and there were plenty) I read and basically described identical sonic gains, could be wrong. I was right and became a huge fan of Tripoint from the moment the Troy started to make it’s magic. I’m in the process of changing speakers, so I’ll write more about the Elite NG/Emperor Mkii combo in the future. What I wrote here are only the most obvious hi-fi superlatives but I also hear new dimensions of sound beyond that and this is hard to explain. Will try to expand on this in the future.
