So more or less they are devices that trap noise created by electromagnetic fields. The star ground system creates a pathway for this back to earth ground. Two different methods that accomplish the same result.
My [rudimentary] understanding is that there is a lot of benefit from sticking a great big old copper post in the lawn and drawing the entire system out to it. But for those of us who live in apartments, with a central electrical conduit with only separate metering...this is as good as we're gonna get to that kind of true earth grounding. Supposedly these things also level out the impedance differences across the different components? That is what i was told by the distributor...also when i mentioned to Zanden what i was doing, that was their understanding as well, and they felt that it would have merit as an approach.
Lloyd
I agree that the benefits for some such as yourself and others living in apts are far greater than others who have a separate subpanel for just their listening room with many dedicated lines. I bet in cases such as yours the effect when you did isolation and grounding must have been jaw dropping
I was under the impression that these external grounding systems did more- that they addressed inter-component grounding issues that went beyond simply having a good electrical connection/dedicated lines, etc.
That's why I was curious to know what they would add to a system like Mike L's, which already benefits from separate electrical feed, isolation transformer, balanced power, etc.
The simple experiments I did, with separate subpanel/dedicated lines, helped address some noise problems i had with super high efficiency horns (which made the noise level of the electronics very noticeable), but I can't say it was jaw dropping. Then again I wasn't using anything fancy for external grounding.
Some one with more technical expertise might be able to explain why the grounding set-ups in each separate component interact with each other in ways that are detrimental.
Simply put it could simply be explained that Lloyd has a far more polluted pool of AC coming into his apt which has 2-3 circuits on one breaker whereas you and I have 12-15 dedicated AC lines each on their own breaker for just our sound room
A noise free system is absolutely stunning,no two ways about it. You add to that a ultra low distortion high resolution system and your jaw gets nailed to the floor. I have talked about this here and there for over 3 years. Every component depending on the internal grounding scheme can benefit from noise removal by some grounding method. When you come down to it music at this level is pretty special,most don't think this level is attainable but it is. Enjoy and all paths lead to Rome.
Lloyd
From the person who started this thread and who experiences the benefits of the Troy se weekly in a high end system that had been worked on for many years and was pretty much tweaked out (or so I thought) one final remark: somehow I get the feeling some people just do not want to believe that the Troy does something very special, also or maybe especially in top notch systems such as eg in Asia with dedicated lines etc. If that is indeed the case (and I hope not), that is a real pity ( for them). To all audiophiles with an open mind I would say: try the tripoint se out. I am pretty sure you will be in for a very pleasant surprise as you will experience your system as you have never heard it before.And I might speculate that for those who have the most rigorous and dedicated electrical supplies to their audio room, such as some people on this thread, would hear a far greater improvement with the Troy than those living in apartments. The thing about the Troy is that the better your system and the foundation it is based upon, the better it sounds. While the price is high, I have determined that it is very reasonable for the improvement and musical satisfaction it provides. I would love to hear the reaction if Steve or Mike dropped one of these into their system. This is not simply a star grounding scheme. Ask anyone who has one. Maybe someone who is skeptical should see if they could have a unit sent for demo.
From the person who started this thread...To all audiophiles with an open mind I would say: try the tripoint se out. I am pretty sure you will be in for a very pleasant surprise as you will experience your system as you have never heard it before.
A few questions.....
It seems there are 3 different types of grounding cables (Thor, Master reference silver, and signature silver).
How long is this cable, what are the differences between the three cables, where does this cable attach and how much are the 3 cables
I gather each of the 3 binding posts can accommodate up to 3 devices. To ground 9 devices will one need 9 Thor grounding cables
