Okay, that makes sense...sounds like another device I am going to have to try down the road.
for sure...
Ughhhhh...mo money, mo money...lol
...at what cost the endless pursuit of 'perfection'?![]()
. . . I want to state that I do believe in creating a star ground system for your components. Ampex Roger on our forum motivated me to try this for my system. I don't need an African Bubinga wooden enclosure with laser engraved metal plates on the top and front of the box though. I just used a chunk of copper bus bar with some holes drilled and tapped for screws and ran a 10 gauge wire from each of my components to the bus bar and connected them with spade lugs to the bus bar. I ran one ground wire from the bus bar to the center screw of the outlet where my preamp is plugged in. My noise floor has never been lower and I'm quite happy with this arrangement. It's not as sexy looking as a polished Bubinga box with "classified" parts, but it does a damn fine job.
wouldn't it be better to run a dedicated audio room sub panel from the house main supply bypassing the main home circuit panel ? I bet it would cost far less too.
Hi,
I was reminded by certain members that I should disclose that I am a Tripoint dealer.But to be honest I was looking to add the best noise reduction/ac conditioner I could find and I could have picked up probably almost any line but after hearing the Troy and Orion against the others,I was more than happy to become a dealer.In my honest opinion with Tripoint,you get what you pay for,performs the best,case work is like a fine piano,expensive yes,overpriced no.
Just to let you know I am also a HRS dealer,Elrod dealer and the Lotus Group.
Robert
Hi,
Robert
Lloyd, perhaps you already described your basic electrical system, but if not, could you describe what your set up is, leaving aside the external grounding products for a moment?
i know it causes me to ponder this question a bit more than before.
