Interesting - please let us know. I would also check with Sistrum if their stands would work with the downward firing woofer.
F1nut said:Ok, it's almost universally accepted that using spikes to couple floor standing speakers to the floor is of great benefit and when it comes to speakers stands, adding mass (shot/sand) and using spikes to couple the stands to the floor is also of benefit. So, why do many say it's best to decouple the speakers from the stand? Would it not be of greater benefit to couple, as in bolt, the speakers to the stand making it one unit?
Thoughts?
Hello, Gary. I hope you are enjoying your weekend.I had a good friend of mine ask a question on another forum I thought to be of high interest. I touches on the topic here so I figured I would ask your thoughts on the subject.
I am actually intrigued by this question, as I have always pondered this whilst listening but never got around to asking. In my particular case, it won't be for a bookshelf or mains but for the subs I have that I set on extremely heavy stands. IME, this yields a better overall presentation, spatial locational cues, impact and overall realism versus placing the subs on the floor. My subs are placed currently with the woofer at the tweeter/ear level. If you would be so kind, would you please mind sharing your thoughts on this subject?
Tom
Hi Gary,
Thank you for your response. As I noted above the extra weight in the stands resulted in greater clarity, which seemed to be a good thing at the lower volume levels I had been listening at. However, I discovered at higher levels the sound became a bit etched. Taking into account your posts and that of allvinyl I placed some soft foam discs I had laying around under the semi-hard rubber feet in an effort to further de-couple the speakers. Hmmmm.....much smoother at higher levels and still nice a lower levels. At this point I've given up on the coupling idea and will experiment with other de-coupling devices.
Thanks again,
Jesse
Try tapping your heal into the floor and listen for the natural resonance of the room itself. If you have a solid concrete floor you may not hear much. But if you have a suspended wooden floor, as I do, then the resonance can be quite severe. I actually put additional supports under the floor joists which helped significantly regardless of which speaker I used. Due to the construction of my room most speakers sound best decoupled from the floor to prevent pumping energy into the floor.
