UPDATE ON RRV ie RIGHT ROOM VOLUME
Status
Not open for further replies.
As I said I listen at realistic levels and that for me is a different gain control for large symphonic vs a solo singer. The difference in gain however rarely varies by more than 2 clicks up or down from my usual gain control position
I see that and respectfully you’re missing out. I listen at the correct level ( and boy is it realistic) and my EXTENSIVE evaluations convince me there is just one setting for RRV. Any changes beyond YOUR RRV ie when you alter the volume, can have a palpable effect on the sound and your enjoyment thereof. Even I’m astonished at how minute changes to the RRV can have. Spot on and it’s smiles all round 24/7
i’m also curious about the loudness level at the listening seat measured in dBA. I’m sure it likely varies by room size and room characteristic.
Also by what device it’s measured with.
Steve, could you tell me what those realistic levels are in decibels at your listening seat for two or three specific recordings that I might have with different scale music, say solo instrument versus jazz trio versus symphony? Thank you
I have posted several times about the importance of repetitive, consistent volume levels for EACH recording. I record the volume level for each CD (on a sticky inside the case) for the optimum listening experience. My CJ pre is set at 0.7db for each numeric value. Settings range from 35 to 65.
I cannot imagine "winging it" for each CD that I listen to on numerous occasions and attempt to recreate the ideal volume again and again. I cannot imagine having a pre without a numerical volume display and a remote that allows me to change that volume level from my listening chair. Then again, maybe I am lazy.
In which case I can’t help anymore Steve. .
Ditto. I’d love to compare. Hope I have the same lps.
I have posted several times about the importance of consistent volume levels for EACH recording. I record the volume level for each CD (on a sticky inside the case) for the optimum listening experience. My CJ pre is set at 0.7db for each numeric value. Settings range from 35 to 65.
Totally agree. You have a defined volume for Each CD rather than one volume for all CD’s
i contend that RRV differs with the genre of the recording and would so state that the ones or two clicks on my gain control locks in perfectly so I only go up or down in the gain control 1-2 clicks and that is my RRV IMO there is a different RRV for each recording.
Since all records or songs aren't recorded at the same level it is impossible to get the same output level at only one volume setting.
You are free to provide the same information for the rest of us to compare. It might be more instructive if this information comes from you rather than from Steve.
Im still interested in cableman's room dimensions
Reactions: PeterA
I'm still interested in trying to understand anything. And since you opened the thread I assume you're interested in talking about it.
I'm glad you have recording experience, this should make the conversation easier. Let's try reducing the problem and try to squeeze out a clearer picture so we're not beating around the bush.
Your hypothesis is that there is one and only one adequate listening volume for a given room/set up. But you state this as 'once you find the spot in your volume control, it's done, don't move it ever again, no matter the source or program material'. Or at least you seem to from what I can see.
Allow me to put forward a small exercise. You record a given event. You make two masters from the same recording: one is simply 5db higher gain than the other, otherwise exactly the same. Disregard clipping, headroom, all the things that would tilt you towards an ideal gain in real life. So you have the same program, just with 5dB difference in gain. Your hypothesis is that you still should not move the reproduction gain/volume, the ideal setting will provide you with the best experience for both masters of this same recording?
Sorry for the reductio ad absurdum, but you seem pretty confident in your claims, so here shouldn't be a problem in digging deeper.
Reactions: tima
Why? It’s tried and trusted. And yes. In due course I’ll suggest various lps and pressings.
And I hope you share your room dimensions and the listening volume at which you listen at your listening seat? The volume must surely change depending on which recording you’re listening to, but I would like a rough idea.
why be so vague about your claims and not share more specific details about the method used to find this right room volume?
Reactions: Bobvin
What is the update and who is Keyser Soze?
Peter FYI the update… that the greatest trick the devil ever pulled was convincing the world that RRV didn’t exist :eek::)
Reactions: tima
If the OP is saying that one volume level fits all recordinds with minor (say + or - 2db) volume adjustments, I am speechless. Maybe I do not understand RRV.
And no OP, Steve does not need your help. To suggest otherwise is very pretentious and disrespectful.
And Steve, if you have detents (clicks) on your volume control knob, I totally agree. Volume knobs that have no such control, that is another story. What is the dB value of each click of your pre?
If he is saying that one volume fits all, I am speechless.
I guess we can at least all agree that the Mute function is the same RRV, whatever the music or room.
I must say if setting your volume at one level and never changing it works for you go for it.
The first time I read this I really thought someone was doing this a little too much. R.png
Reactions: Bobvin and Audire
It really is astonishing... there is a claim that RRV is one particular value, clearly room dependent. But the fellow advocating for this isn't willing to share 1) his own value in terms of a db measurement along with some details about his room and/or 2) some method by which one goes about determining this RRV.
It would seem to me (but as I said before, I am just a layman) someone so devoted to telling the world about RRV he'd be willing to share his method/technique so we could all bask in the glory of RRV.
Otherwise, this thread is a repeat with no new information, i.e. worthless troll slobber.
Reactions: ecwl
Status
