The audio industry version of SPQR
@ Tim... I think we're on the same wavelength here on several points. Let me expand on some of them.
We are definitely trying to act as consultants to the readers, helping them get up to speed on how to listen and evaluate. Don't rely solely or even primarily upon reviews, use them as a point of reference, and find out for yourself if you agree. You're (the consumer) spending the money. You're the one who the industry needs to satisfy.
Now, giving the manufacturers feedback ultimately should benefit consumers as well. All the constituencies here are closely interrlated. And the family is very tightly-knit. We better get on.
Let me give you a recent example.
We got an initial production run unit of a particular product from a well-known (but small) company. It wouldn't synch up to certain other products, under certain circumstances, and both products enjoyed well-deserved good reputations. Uh, oh: Consumer nightmare on the horizon. it should work, but it doesn't.
To make a long story short, after getting everybody together by e-mail, talking with other purchasers of the initial run, etc., it turned out that the problem stemmed from a mistake in the "recommended design" specifications (wrong part value) from an OEM manufacturer. Ooops.
It took a couple of weeks for the designer to find someone at Gigantic International Electronics, Inc., who understood the component well enough to track down the mistake. And it would have been hard for the original designer to have corrected this problem, without feedback from reviewers, consumers and in this case, competing firms. Even if it's "someone elses" fault, both companies get "tarred" in the mind of the consumer if there's an integration problem.
Result: The Initial units were withdrawn from the field, the mistake corrected, new units go out, and things are much better for all concerned.
BTW almost all the gear that comes through here is from companies that are tiny, as mentioned earlier. Most "large" high-end audio companies are small (or very small) businesses by most criteria. Outside of forums such as this, the general public has never heard of them.
For the high-end audio industry to survive, consumers have to have a positive experience or they'll spend their time and money on something else that gives them more pleasure, rather than aggravation and frustration. Sure, an approriately negative review could be helpful, but I'm not sure the messages delivered generalize.
Thus, appropriately and realistically written positive reviews, in my opinion, are better educational tools. If the marginal products are weeded out of the review process, then it will never be necessary to be "diplomatic" about shortcomings, which in my opinion, doesn't serve consumers well.
Just present the really strong, high-performance and high-value products correctly and accurately, compare them with competing products that should be auditioned, and the consumers should be really happy.
As you say, trust your ears.
