Interesting to see Ethan advocating a subjective approach.
The first thing I suggested is measuring the system using room measuring software. The second thing I mentioned is a blind listening test. A blind test isn't subjective if it's done properly. Sadly, all the people who insist the benefit of isolation under gear "is so obvious" and "the system as a whole takes a performance leap forward" live too far for me to visit in person to see if they really can tell With versus Without. And when I've offered to visit local people such as Michael Fremer, Myles B. Astor, and Jeremy Kipnis, among others, they always refuse. I'm sure I know why they refuse. So until proven otherwise, I'll continue to believe that isolation works mainly on placebo effect.
Transistors and ICs are susceptible to microphonics though not as much as tubes.
Unless you've tested this using sound generators, and measured output voltages versus frequency and SPL amounts, I doubt you have any idea how much air-borne vibration is needed to affect solid state equipment. As always, I'm glad to review any hard data you have.
Ethan is correct in that most vibration is airborne; an anti-vibration platform is effective at draining off such vibration if used correctly.
How can a pillow underneath a preamp reduce vibration into the preamp via the air? Please be very specific.
Bob Worzalla of Sound Anchors showed many years ago that speakers also benefit from platforms or stands. He did this by aiming a lazer at the cabinet of the speaker itself and observing how it changed when on a proper stand.
This is meaningless because artifacts can be measured that are too small to be audible. If he also did listening tests, but they weren't blind, then those were meaningless as well.
--Ethan
