VPI Uni-Pivot tonearm Lubricant
Temaad
2
72
Hi, I have repaired my wires in my tone arm. Now I am going to mount the arm this weekend hopefully. But just looking at things as an engineer, Is there a lubricant that goes into the cup of the tone-arm. It seems crazy to me not to have any, but cannot find it mentioned on the net. Reading through as many arm manuals that I can find from VPI & none mention lubricant. Also interesting to note that they recommend not using the anti-skating mechanism.
Cheers
Fishfood
537
541
255
44
No, there is no lubricant. Also be very careful with "no anti-skate" and the twist in the signal wire to compensate. My cartridge cantilever was bent by unknowingly (it had zero effect on the sound) using too much anti-skate in twisting the wire.
sbo6
1,679
606
480
Round Rock, TX
FYR - Just got back into analog and my VPI Aries 3 has tonearm damper fluid, so it does exists.
audio.bill
550
91
340
Chicago suburbs
Tonearm bearing lubricant and damping fluid are two entirely different things. Some of the VPI arms had a reservoir around the bearing spike where the damping fluid they provided could optionally be used. There is no lubricant of the tonearm's unipivot bearing itself.
