No, TAD's did not extend lower, there was a tapped horn covering from 45hz to 18hz.
Ah OK. Got it.
Mani.
My first experience of horns was the Chopin several years ago and it was an unforgettable experience. I took Kempff’s Beethoven Piano Concertos CD over and the detail/resolution and colours of the Chopin was astounding. When you listen to Mozart’s Concertos for 2 and 3 pianos you can tell that there is a more expansive sound created as the pianos are played in almost perfect unison. There’s more colour and effects than with just one. I had the same experience listening to the piano in Beethoven’s piano concerto 5. Only one piano this time of course, but I could again hear the varied contribution and same expansive sound of the multiple strings when a single key was struck. Rare for drivers to be able to dissect out such detail off a keyboard. I later auditioned the Liszts in Denham and there was more yet again with string section of the orchestra. Something about the blend of these TAD drivers and the general recipe in these speakers. The directivity of the bigger speaker of the Liszt over the Chopin in a similar sized room alleviated any anxieties I had about reflections and room contribution massively. Cessaros are deeply impressive and if I had the time, money and space (minus my 3 young kids) this would bring many years of pleasure.
Micro's statements in less than a day (... )
If you want to address my points and get my answer please quote me directly as most others do in this forum and I will answer. Your style of misquoting, changing the sense and the framework of ideas only serves to avoid discussing important or fundamental aspects of this hobby and keep the debate superficial, most of the time centered on old dubious myths.
No one will change his preferences because of WBF, it would be nice if we could understand the why's of them.
Your one post is the one which mani quoted, to which I replied. Your other post I quoted directly on another thread. You can do the search. You are the one misquoting regularly. Your post on this thread in No. 15 blatantly making up stuff
Again, sorry, I do not enjoy your charades.
The main characteristic of horns is its pattern of radiation, in general being more directive than "regular" box speakers.
This means the ratio between direct and reflected sound is higher in horns, resulting in more recording and less spaciousness.The stereo illusion needs controled wall reflections. Being an advantage or disadvantage is a question of listener preference.
I’m not sure why you choose Wilson speakers then as off axis response or controlled wall reflections is quite poor compared to others?
Nor I yours. Stop spreading false statements and misquoting like horn owners mainly listen to vintage LPs, and at 120 db.
I expect horns to be much more different between them than regular speakers - as shown by simulations by ray-tracing the reflections needed to create an higher efficiency create some coloration, no horn shape is perfect and the reflective properties of materials vary along the spectrum, each horn has typical sound pattern.
I found interesting that people who favor horn speakers seem to listen significantly louder than those having box speakers. However we only had a few data points in another thread, this subject deserves more research.
Sound engineers balance their recordings to be listened in box speakers. IMHO if you want to listen to the recording as expected by their creator you should use a speaker with a similar pattern of radiation.
Interesting reply's I like horns quite a bit! I find it interesting when the transient speed of horns is discussed there seems to be the impression that in most cases dynamic speakers cannot keep up. I have certainly been left with that impression at times
The problem with this is you use dynamic drivers to drive the horns. About the only thing the horn can add is directivity and some gain. The dynamics we hear are all from the driver not the horn.
So why the common belief about dynamics??
Rob![]()
^ Why the common belief? Experience with horns makes it so inherently obvious. Are you questioning whether the perceived dynamics are actually real or asking why horns are more dynamic?
correction: 110db will take 10mW not 1mW.First, while technically speaking a compression driver is a kind of dynamic driver (meaning it is a dome or ring with a voice coil) it is of a special breed that is designed to work specifically with a horn and has a compression chamber. This means it also has typically an enormous motor (usually much bigger than the driver itself...the reverse of a typical cone/dome). For example, the CP755Ti that I use in my new DIY system have a 3 inch titanium dome but the overall magnet structure is nearly 8 inches in diameter. This means you get something like 10db higher sensitivity even without the horn and with the horn maybe 20db higher sensitivity (my CP755Ti have 110db/watt in a horn vs the typical 88-93db dome).
This means two things: 1) the driver excursion for a given output level (let's say 90db) will be much less and therefore so will distortion and 2) The onset of thermal compression, which afflicts ALL drivers, is pushed away by about 20db. A 90db driver at 90db will be already passing a significant amount of current through the voice coil, which means it is already quite warm...now a transient comes and it heats up very rapidly and will not scale that peak correctly but will compress it. The 110db driver is passing a few mA at most and so even if the onset of compression for both drivers is the same based on the current passing through the drivers the 110db driver will still be able to respond with much less compression due to far less heating of the voice coil (because the peak will require less power as well to capture). This is also means it is scaled with far less distortion both linear and non-linear.
Don't underestimate the benefit of gain. 3db is double the power (but only in an uncompressed state as the SPL goes up it takes ever more power to get 3db more) and that means a lot of voice coil heating. 10db is 10x the power. So, if at 90db a 90db driver will take 1 watt but a 100db driver will need only 100mW and a 110db driver 1mW!
I have seen a number of conventional cone and dome drivers used with horns as well and this also helps them with dynamics and boosts their sensitivity by a few db (you cannot apply too much compression on them I think as they are not really designed to handle those pressures). It lowers their distortion at a given output level and allows them to scale dynamics better than without the horn...but they don't get the same output per watt that a compression driver gets. So getting 3-5db more sensitivity from a conventional driver actually still means a lot of advantage than without the horn.
So, it is not only a common belief, it is demonstrable from physics.
