What Credentials Should An Acoustician Have
Steve,
here's my take.
Steve Williams said:
...I have begun wondering what people look for when choosing an acoustician...
It has been said in the thread, that knowledge of the acoustics of large spaces does not necessarily mean that those guys are capable of doing a good job in small rooms. It’s not a mere matter of downsizing/downscaling, this becomes very clear when you look at perceptual thresholds of e.g. early reflections. Small rooms as such have very different issues, and the fact that music is reproduced by (more or less directional) loudspeakers adds an extra layer of complexity, just think of adjacent boundary effects.
What I would expect from an acoustician is that he is familiar with the technical literature relating to small rooms and related psychoacoustics, Floyd Toole’s book and the references cited therein would be the strict minimum. Are acousticians aware of the fact that human hearing has its very particular manner of processing sound, which is very different from a measurement microphone? Does the acoustician take equal loudness contours into account when measuring room mode amplitudes, does he know about binaural decoloration when addressing the issue of early reflections? Does he know about the interaction loudspeaker – listening room? The speakers’ off-axis behaviour has been mentioned: does he ask to see measurements? Did he ask for measurements in your case, Steve?
However, having read large parts of Toole’s book and many of those references I would say that in most cases an acoustician is not needed simply because there are no problems that need to be solved. As an example a quote from Toole: “the widespread belief that these reflections should be eliminated as a matter of ritual.” It is quite simple, for most, if not all of the rituals in small room acoustics there is no supportive evidence. It is done, without having investigated if the problem actually exists perceptibly.
It has also been said that “there is not an information enough about small room acoustics that allows someone to make an educated choice”. I beg to differ: there is plenty of information, Toole’s book for instance, and research is more and more focussing on the perceptual aspect of things, as becomes evident from the AES. Since it’s humans who listen to music in those small rooms, you must consider the perceptual side of the issue, you cannot rely on measuring alone.
...and yes has an incredible ear for music
As is known from psychoacoustic literature, in-ear frequency response may vary considerably from one person to another:
Shaw, "Earcanal pressure generated by a free sound field", J. of Acoust. Soc. of America 1965, vol. 39, no.3, p.465
Which simply means that what another person hears might be irrelevant for you:
Philip Newell, "Recording Studio Design", Focal Press 2008
"In my first book I related a story about being called to a studio by its owner, to explain why hi-hats tended to travel in an arc when panned between the loudspeakers; seeming to come from a point somewhere above the control room window when centrally panned. The owner had just begun to use a rather reflection-free control room, in which the recording were rendered somewhat bare. On visiting the studio, all that I heard was a left-to-right, horizontal pan. We simply had different pinnae."
and
"Studio Monitoring Design (Ph. Newell 1995) also related the true story of two well-respected recording engineers who could not agree on the 'correct' amount of high frequencies from a monitor loudspeaker system which gave the most accurate reproduction when compared to a live cello. They disagreed by a full 3 dB at 6 kHz, but this disagreement was clearly not related to their own absolute high frequency sensitivities because they were comparing the sound of the monitor to a live source. The only apparent explanation to this is that because the live instrument and the loudspeakers produce different sound fields, the perception of the sound field was different for each listener. Clearly, all the high frequencies from the loudspeaker came from the very small source, the tweeter, whilst the high frequency distribution from the instrument was from many points - the strings and various parts of the body. The highs from the cello radiated, therefore, from a distributed source having a much greater area than the tweeter. So, given the previous discussion about pinnae transformation and the different HRTFs as they relate to sound arriving from different directions, it does not seem too surprising that sound sources with spatially different origins may result in spectrally different perceptions for different people."
Klaus
Most rooms I've been in, whether being employed as a acoustician or purely to check out someone's system, are of the size where room mode issues in the bass and strong reflections from nearby boundaries create a 'non-neutral' environment for the equipment. I have been in very, very few rooms that were 'inherently neutral' and did not impart some aspect of themselves negatively on the music. Maybe because I have heard a lot of systems in a lot of rooms I have a better idea of what neutral sounds like than most people and have 'attuned' myself to room acoustics issues...or maybe it's because most don't have a reference in their mind of what neutral sounds like and live with some measurable and audible issues like a 10dB dip between 30-40Hz or a couple of peaky and slow to decay room modes at 70-90Hz.
Toole dismisses two channel pretty much right out of the gate because it cannot create appropriate spaciousness and envelopment cues. He also uses multiple subwoofers in specific arrangements and if you go to the back of the book you will see his designs for rooms have plenty of acoustic treatment in them. I'm not sure why people read Toole's book and immediately think that there are no problems to be solved. There are plenty! I have seen a couple of people now interpret what Toole says about early reflections as meaning - well I don't need anything there because those reflections are 'good'. Well that only refers to the lateral reflections and only if you have speakers with good off axis response to begin with. Don't get me wrong I am a Toole 'fanboy' and he reviewed the white paper that I wrote with Jeff of HDAcoustics but I think people sometimes get the wrong message from reading his book.
Jeff,
Great post!
I also have read the Toole book and loved part One - Understanding the principles. However after I went through the first pages of part Two - Designing listening experiences, I understood that it would not cover my main interest - stereo listening. I enjoyed this part, there are plenty of interesting details and technical aspects, and his style showing the limitation of current knowledge and possible solutions is also very enjoyable.
For me one the best parts of the reading was understanding the limitations of stereo and how with the help of our brain we can surpass them - how most of it could be summarized in the great sentence - stereo is an individual experience. And all I have read in the second part helps me understanding and participating as an amateur in acoustic debates. But I understand that just having read the book and some of the texts referenced in it does not turn me in an acoustics expert, even with the help of the REW measuring package and the CARA simulator!
Nyal,
With all due respect, what is neutral to you, maybe not neutral to someone else, in-ear frequency response is different for different people, so we perceive the same sound differently. The German acoustician H. Kuttruff writes: "In the case of music the success depends on the achievement of other, less quantifiable conditions and at last on the personal listening habits of the listener. In any case, good acoustics as such of a room does not exist."
As for mode induced dips and peaks, a measurable difference of 10 dB may disappear when converting SPL to Sone. As for mode decay, there is research published which I yet have to read. But when talking decay, what about the speaker's decay in the waterfall plot? To what extent is bass driver decay responsible for audible mode decay?
Strong reflections: you've mentioned off-axis response yourself, to what extent is that response responsible for audible problems?
Of course, a room with concrete walls will behave differently as compared to a room with walls from gypsum board on studs, but it’s the source’s position that determines how it couples to the modes. When you listen, you don't judge the room, you judge the speaker-room interaction as perceived at the listening position. Move the source and it will sound different, while the room doesn’t change.
My experience in my room is that modes are not an issue, but then my system with its good measured behaviour and room with its acoustic ceiling are probably not representative. Still, the modes are easily audible when playing test tones.
Maybe that in those rooms which "imparted some aspect of themselves negatively on the music" the choice of locations of source and listening position was unfortunate, maybe the frequency response of the speakers was lousy. The only aspect of the room itself I can think of to affect the sound is reverberation time.
Toole dismisses 2-channel, yes, for reasons he personally considers valid, no problem with that, and he’s probably right. In my room I can’t place a surround system like it should be placed so I never was interested in surround, and therefore never investigated the technical literature. The use of multiple subs is justified for a system with a listening area for seating several listeners. For a single listening place other solutions may be sufficient.
I’ve read all of Toole’s references relating to early reflections, and a few more, and there is no evidence that early reflections in 2-channel stereo are a problem as a matter of principle. I’ve prepared a write-up on this.
The fact of reading the references adds valuable information to what is stated in Toole’s book. For example, on p.116 Tool writes w.r.t. Kishinaga’s experiments: “Adding absorption to the front wall, behind the speakers, reportedly improved image localisation and reduced coloration”.
For the experiment with absorption added to the front wall, all the other walls of that room were absorptive. The front wall was changed in 6 steps from reflective to absorptive. Results were tighter bass, improved localisation, other parameters did not change or worsened. It is known that the fewer reflections remain in room the more the individual remaining reflection may affect the sound. Reverberation time also has an effect: the lower, the more the individual reflection may become a problem.
* Bech, “Timbral aspects of reproduced sound in small rooms I”, Journal of the Acoustical Society of America 1995, vol.97, no. 3, p.1717
* Salomons, “Coloration and binaural decoloration of sound due to reflections”, PHD Thesis, Delft University, 1995
Clearly, the above results have to be seen in the context of the room of that particular experiment where reflections from side walls and from behind the listener were absorbed. This combination of data leads probably to conclusions different from Toole’s. With all due respect to Toole, this case demonstrates why I consider it useful to read the source documents themselves.
The global conclusion is that one has to examine each case individually. There might be cases with strong right-left asymmetry where treatment may be beneficial. There may be cases of loudspeakers with lousy off-axis response where treatment may be beneficial. However, the general approach is that reflections are bad and need be treated. Recommendations of EBU and German sound engineers/Tonmeisters are along those lines.
In my own case distance alone accounts for the lateral reflections being 7-10 dB down, off-axis response adds another 3-6 dB, which puts me right where your white paper, EBU 3276 and SF-01.2002 recommends to be. In view of this, I’d need no acoustician any more. However, for music thresholds for lateral reflections are 18-25 dB down, and what now?
Klaus
and
Klaus
a fascinating comment and one with which I agree
My room is complete, short of determining final speaker position before I take them off their casters and spike them. people have been asking me for a write up and photos of the build out. I have yet to do this as I am trying to determine just as you suggested where the best speaker position is to minimize any issues. What I can say with 100% certainty that I find very positive is the bass response in the room which even without subs (a pair of Fathom subs on order) sounds simply amazing. This was something in my last room which I did not have and only benefited from a pair of Gotham subs. I do agree that taming a smaller room was a far bigger challenge for me than when I did my last room. Measurements so far do show a slight drop off around 50-60 Hz which I am hoping will resolve with the subs. Having said that I must say that the bass in the room sounds simply magnificent
(...) and yes has an incredible ear for music
Steve,
Perhaps it should be written as and yes, has an incredible ear for music and for client preferences!
Long ago I asked a famous architect to project a house for our family. After we had a first meeting in his office, he told us immediately that we had to invite him to have lunch with the whole family. As he friendly said - I have to know what kind of fools you are in order to design a house where you feel comfortable! He designed an wonderful house and we become good friends until his premature death some years ago.
Unhappily I am not able to find a good local acoustician with whom I can repeat a similar experience. All those I have met are too influenced by their experience working for sound professionals, mainly in studios and discotheques, and do not want to listen to unusual customer preferences.
First and foremost, I believe an Acoustician should have the finest hearing aids available. Oh, I am sorry, I ment reviewers.;)
Eh?! Speak up sonny, i can't hear you! :)
(That was funnier as I wrote it in all-caps, but the forum software translated them to lower case...)
LOL, still funny in lower caps.:cool:
