'Fraid not-- my none too shabby 300B
BruceD
Assuming it works, do you know what it is doing? Something in the feedback loop perhaps?
BruceD
Just came across this YouTube video, https://www.youtube.com/watch?v=Ynac5mvrcQ0, of the Newport show, and at the beginning these is a demo with nominally high performing components, using big Evolution Acoustic speakers - with truly awful, "hifi" sound. How many times does one bump into this - a thousand miles from being believeable, all that money thrown at it with little audible benefit ...
Hello Frank
Why are you making judgements about the sound of the system using a Youtube Video?? I am seeing this more and more of this on forums and frankly I don't get it.
Rob![]()
Steve Williams; [B said:I totally agree Rob and like you find judgments made on You Tube videos to be getting out of hand[/B]
FWIW Frank the Evolution Acoustics room was tied for my best sound at THE Show (tied with Philip O'Hanlon's room ) but then I again I was there. Pray tell Frank how you make that comment from You Tube. If you had read the comments from those that were there many commented as to how great the sound was
Steve, I can only judge by what I hear, in the video - and in that particular clip there are qualities there that I recognise, which to me are a giveaway of what is troublesome about much audio sound, it has a "signature" that says loudly, "I'm a hifi system". The quality when you were listening may have been much superior, and hence the disparity in viewpoints.I totally agree Rob and like you find judgments made on You Tube videos to be getting out of hand FWIW Frank the Evolution Acoustics room was tied for my best sound at THE Show (tied with Philip O'Hanlon's room ) but then I again I was there. Pray tell Frank how you make that comment from You Tube. If you had read the comments from those that were there many commented as to how great the sound was
Yes, most likely the digital source - ambitious systems can highlight all the negatives of digital playback so easily, and are then impossible to listen to for any length of time.Frank, what do you think accounts for this? I wonder if it had anything to do with the digital source, which I did not notice the name of. The TT was not playing.
Hello Frank
Rob![]()
Since this thread is about believability, that quality of being convincing should come through strongly in a video clip, I have pointed many times to YouTube items which are highly competent in the sound coming across - there is no need to be in the room to hear whether that quality may be possible, if a video obviously highlights issues, then it will be even more clear in the flesh.
Again, there is nothing inherently a problem in those components - but in that instance of of a system performing the sum is significantly less than the parts; it instantly reminded me of many, many demos I've heard over the years ...
Rob, I'm not worrying about evaluating the positive qualities, merely whether any negative qualities are obvious - if they can be heard on a video clip, then they surely will be evident in the flesh. The AVshowreports channel uses a very recent LP pressing, at decent volumes, in the clips, and compression and lacklustre reproduction of the transients by some of the systems is very evident - this is useful feedback.Why are you making judgements about the sound of the system using a Youtube Video?? I am seeing this more and more of this on forums and frankly I don't get it.
Rob![]()
Hello Frank
Rob![]()
This is a crazy trend in the internet - unfortunately it is becoming usual. We had the problem of people expressing opinions concerning the sound quality about equipment they never listened - now we have the people that writes with familiarity about the sound of equipment because they listened to it in youtube.
The video is acting as a measuring tool - you have a record of what was presented to the microphone in separate rooms, using the same recording device, the particular camera in use. In one room the presentation comes across very impressively, in another rather lame. You can play those videos over and over again, jumping back and forth between them, even analyse the audio component using software - you're able to direct compare two different systems at your leisure.When you say it is evident, you verified that what seemed compressed and lacklustre in the video was also the case in person? How else could you verify that. Your judgement seems to be based on the videos alone
