It doesn't have to be "awful" at all - the recording circuitry in modern phones is actually quite competent, playing such a recording back over some tiny speaker with a very ordinary amplifying circuit is not going to give one much idea of the potential. And, yet again, we have the idea that YouTube audio quality is intrinsically bad - of course one can upload a bad quality audio for a clip, and that proves, what? If one takes care one can add a sound track to a clip, that can be downloaded and converted to conventional audio formats - and if played back over a decent system, with the original, pristine track to compare against, I would suggest that 95% of the people reading this wouldn't be able to pick the "dodgy" one ...How could the sound be anything but awful -- it was recorded on a cell phone and then played back on Youtube? (I think this is why the sound in every demo room in the video, recorded by the cell phone, sounded tinny.)
Good suggestion, Peter! And going back to it, I find it hard to imagine anyone thinking it was "good": the percussion sounds in the mix are barely recognisable as to what they actually are, a highly jangly, over emphasised mid-range, boxiness, a PA shoutiness, no real treble - to me the impact is of an over loud transistor radio. This song should be very mellow, with a sophisticated patina to the sound - and that's the last thing I'm hearing.Frank, could you be a little more specific about what you hear in this video that you find makes the system sound "hifi" and lacking in believability. Specifics may help us to understand the point you are trying to make.
The video is acting as a measuring tool - you have a record of what was presented to the microphone in separate rooms, using the same recording device, the particular camera in use. In one room the presentation comes across very impressively, in another rather lame. You can play those videos over and over again, jumping back and forth between them, even analyse the audio component using software - you're able to direct compare two different systems at your leisure.
Music enthusiasts compare recordings of a particular work, done at different times, by different musicians, all the time - no-one says that you can't do that, because you weren't in the recording hall of these events. Enough information is captured in a recording to tell one what's going on, if one knows how to listen for ...
Just came across this YouTube video, https://www.youtube.com/watch?v=Ynac5mvrcQ0, of the Newport show, and at the beginning these is a demo with nominally high performing components, using big Evolution Acoustic speakers - with truly awful, "hifi" sound. How many times does one bump into this - a thousand miles from being believeable, all that money thrown at it with little audible benefit ...
Hello Frank
Why are you making judgements about the sound of the system using a Youtube Video?? I am seeing this more and more of this on forums and frankly I don't get it.
Rob![]()
With all due respect, this is absolutely incredulous. Making judgments based on something recorded on a cell phone and a U Tube video.
And of course all the biased analogue groupies immediately know or imply that the apparent distortion was caused by a digital source.
Do you have any idea how silly this sounds?
Are you all serious?![]()
Hi
I can't understand how some can so repeatedly fall for fas42 leg-pulling... He' s been doing it in many fora...
Yes, most likely the digital source - ambitious systems can highlight all the negatives of digital playback so easily, and are then impossible to listen to for any length of time.
Wrong
I cannot believe you are being serious at all, so I will not address this as if you were.
I think you or someone mentioned you were an engineer. Is this true? What area of engineering did you get your degree?
And by the way, the source was master tape not digital.
