What differences Shunyata digital spdif vs clock 75 ?
Antmou
4
45
Hello
this is not really clear
1) what are the differences between any bnc-75 vs spdif versions ? (Spdif should be75 anyway….)
2) which one to use for my cd transport spdif output (rca) to mscaler (bnc) ?
3) which ones to use between my mscaler and hugo tt2 (pair of bnc cables)
This has been complicated as we all thought spdif should be 75 so why a “clock 75“ ?
thank you for clarifying
Hi
In terms of usefulness, I connected my DAVE and M Scaler with two Alpha v2 Clock 75 cables and the sound quality improved significantly over the stock cables. I would like to upgrade to OMEGA Clock 75 in the future when my budget allows.
I do not know the name or technical details.I highly recommend contacting Shyunyata's customer support team for more information. Have a good musical life!
The clock-75 and spdif with bnc connectors are the same cable. My dealer confirmed this with Shunyata. I’m using a Shunyata Alpha v1 spdif as a clock cable. I had a pair of these at one time for use with an MScaler.
