Can't answer that without knowing the meaning of the word resolution.
Many/several people on the thread think it means 'more detail'. Use their example.
Hi Micro,
Are you responding to me or you just want to make quotes from an audio preacher for us to explore his view of resolution, focus, detail? Can I imply that you agree with him?
Anyway, this quote I do not relate to resolution.
" also resolution) That quality of sound reproduction which enables the listener to distinguish between, and follow the melodic lines of, the individual voices or instruments comprising a large performing group"
What he said above is contrast and differentiation to me. You said he clearly separate resolution from details. This he accidentally got it right. "Contrast and differentiation" should clearly be separate from details.
What is your definition of resolution Micro?
kind regards,
Tang
My 2p. It’s actually the amp-loudspeaker combination that produces the magic. Without that synergy youre on a losing streak.Greetings from Melb! We're finally out of lockdown and the "resolution" is now greater! Too many people running around like those pixels on our screens...
Speaking of which, I may add to this rather interesting topic: a short discussion way back in time with Jim Winey of Magnepan. As we were ordering our very first MG20 series panels, back then we hadn't experienced anything larger than the MG3.6/r then the first MG20 was on order. I asked the boss, so what's the big deal with this larger panel, other than more bass and a much taller tweeter? Jim replied in one word, "resolution!"
Ah! There it was indeed, greater resolution along every Maggie model, which is also found in other types of panel speakers. Probably the reason why we were so passionate about panels in general. Definition, clarity and quality of holographic images resulted in improved resolution and that's why now, fast fwd 30 yrs and I simply love the way full range ribbons and stats deliver that brilliance in transparency.
From that point made by Jim W and about the same time as Gayle M Sanders, when I experienced the ML Statements Evo-II's, this resolution factor became even more obvious. It's definitely a marvellous thing, and to me greater resolution/ transparency makes more sense in speaker selection. Of course there is other gear in the system that contribute towards this, for example DACs and Clocks. However, I find that no matter how much you were to spend on external gear, I firmly believe it's the speakers that provide that fine level of resolution.
At the same time, I would also believe too much resolution leads to greater transparency, which also highlights bad recordings... oh well, can't win it all, as long as the music is mighty fine!
Cheers, and do enjoy those fine tunes!
Best, RJ
Absolutely! Without a doubt.My 2p. It’s actually the amp-loudspeaker combination that produces the magic. Without that synergy youre on a losing streak.
I think I definitely feel that this is not at all necessarily the case. I think Kedar had an excellent point, above, with regard to Tannoy Westminster.
I think a system fronted by Tannoy Westminsters and driven by tube electronics will, to my ears, easily sound more real and natural than a system fronted by YG XV driven by Boulder electronics. But I very likely will find the latter system to be more highly resolving, to be a more finely pixelated microscope image of the music, rather than the less finely pixelated reproduction of the more natural and realistic, yet less granularly resolving sound, of the former system.
This proves, to me, that there is not a direct correlation between increasing resolution and increasing naturalness or realness.
After further thought, Peter, and our discussion today, I think that combining naturalness with resolution creates more definitional and comprehension problems than it solves.
I am more with Tang on this one. I think of resolution as an audio version of being able to see things more clearly in a photographic image -- being able to resolve details more clearly in a photographic image. Whether or not the color palette of the image is accurate and true-to-life (natural) I think is a separate question than the resolution of that image.
Is there a point where greater resolution causes an audio system to sound less natural?
Of course there is.
I hear systems that have exaggerated high frequencies that do not sound real but that people think are higher in resolution. Same with big bass. If it is not believable, how can it be resolving?
Thank you for participating in it!I think we just have a different understanding of what resolution means but that’s fine thanks for starting the thread.
Yes the drugs where a lot better in the 70's and 80's !Back in the day I managed to get the music in my rather small listening room to appear to literally fill the room even to the point of music seeming to be coming from behind my seating position. It was like being in the middle of a star cluster. Omnidirectional- music from all directions and you smothered in it soothed and overwhelmed by it.
Many from far and wide including hi end manufacturers journalists and music professors came to hear and were mesmerised. They went in skeptical. They came out jaw dropped. I called it ‘the perfect sound’. I didn’t worry about resolution or detail or clarity or soundstage. It was just ‘all there’. In spades. Oh how I wish I could get that sound back. Today it sounds immense, wonderful, beautiful etc to everyone except me. I believe I experienced the holy grail and I’ll keep searching till I find it again.
Nothing should be exaggerated. Everything should sound ‘appropriate’. Just as the artist who performed it intended it to be heard. As someone who has worked in some of the most famous studios in the world (and yes including Abbey Road) I can say without fear that if I play a record I personally have been involved with, my ‘musical memory’ kicks in and I can at least be reasonably confident when it feels and sounds ‘right’.I do not think that turning up the "Sharpness" control on a television set increases native image resolution.
But I also think that resolution is different from exaggerated high frequencies or frequency balance. I continue to feel that exaggerated high frequencies or tiptop frequency balance is not greater inherent resolution (intelligibility or fineness of musical information) but rather Contrast or Brightness control.
I think we have highlighted our disagreement. I think believability (or naturalness or realness) is
If the recording is of a violin and it sounds like a viola, there’s clearly something wrong with the resolution of the system.
And yet I never took any. But thx for playing.Yes the drugs where a lot better in the 70's and 80's !
We see a finer image of the rose on the 4K video panel, but the color is not any more correct.
