I am actually in the middle of a very similar experience with amps now. I have been using Kt push pull type amps for a long time. I recently bought an 845 SET amp. When I put my kt amp back into play I noticed how SS it sounded compared to the SET.
I'm very pleased I'm not the only one who's used good digital as a benchmark to improve analog install against. I know that's heresy to the vast majority of lp fanatics. But it's worked out way better than I could have imagined.I started a thread in another forum noting the reviewer Paul in TAS issue 306 uses dsd files to assess true to source, then gauges a turn table performance against it.
I noted the same as I was building and learning. Digital was necessary for my understanding proper balance of the tone in my vinyl to keep bloat, bumps and dips out. I did indeed use my digital to get my analog to sound like my digital. Once there I had a baseline and could now start to separate them again to optimize what each does best.
I have PAP Trio 15 open baffle speaker with exposed crossover. As such i have tuned my speaker crossover component and wires to my kt amp. In order to use a SET amp, i need to adjust these items for optimum playback. I say that as others have alluded to vinyl and digital being so different the rest of rhe playback system is tuned to one or the other. I don't find that an issue in my system. The speaker amp relationship is far more impactful than the source relationship. IMO, if your sources are tuned correct, they should sound dam close to each other. I have a record ((National Wake - Walk In Africa) light in the attic records). On my system and Ultrafast system the record is indistinguishable from the digital. I say that as any digital vinyl comparison is flawed unless one has an absolute master that is exactly the same. Buy the National Wake record and play it against Qobuz. I bet you will be shocked how hard they are to tell apart.
The KT88 is cleaner and darker background. A little more linear. Pretty decent jump and snap. Decent PRAT. More solid and controlled feel to bass. Richer fatter bass. It blends seemless with my speakers and does not offend in any way.In which manner does the Kt amp sound SS to your ears compared to the SET?
I have been through 4 dac and even more iterations of 3 servers I have had factory updated as well as personally optimizing software. With all digital, the basic tonal structure is the same. Digital is pretty much always close to what the source is. It rarely has any deviations such as dramatic bloat or incorrect tonal structure. Its always pretty correct. The improvement come from less noise and a more organic and natural sound.I'm very pleased I'm not the only one who's used good digital as a benchmark to improve analog install against. I know that's heresy to the vast majority of lp fanatics. But it's worked out way better than I could have imagined.
The SET tube amp has a magic that jumps out. Horns, strings have an alive, natural and so real tone. Instruments are much more natural. But, your aware you have tubes. There is background noise. The tubes are making so much gain, tapping one is an explosion of noise out the speaker. You have to have premium tubes to avoid microphonics. The speed of bass is very fast. You hear the strings on a stand up. Not so much feel them as a punch or thump. The balance is a little forward. I hear the horn as a separate driver from my woofers. I will have to adjust cabling and caps to blend them again.
My expression of the amps is a more dramatic expression of what I hear in my digital to analog. Its just no where near as pronounced. The digital is a touch darker and more solid. The vinyl a little more air and natural. Both are tonally balanced and pretty linear. The vinyl is more unforgiving of a bad record. The digital will make a less than optimum recording ok, but it wont draw you in. The digital with a great file will draw you in and surprise you with guts, energy, scale and weight. The vinyl on a great record stops you in your tracks. Holy Shit is all you can think. That is just beautiful.
I thought so to K.Rex.This is beautifully written!
But I have to ask: then why bother with digital at all (other than convenience)?
Though Ron I’d suggest there’s way more at stake with the different mediums than just a matter of convenience.
There is broader and deeper music accessibility... a possible ultimate goal for many a music lover.
Convenience is more of a driver for people who are a bit too senescent to get up and swap an album over between their martini’s... and I get that. Also I’d imagine then wisely living with the anxiety of accidentally knocking off your diamond cantilevers on your Ortofon Annas in above said inebriations.
There are many good reasons for both these mediums otherwise we probably wouldn’t have such strengths of concentrations in each.
The way digital and analog handle information is quite different, it is not easy to conciliate them.
Could you please specify? Thanks.
It relates with the amount of information the formats can handle. Instruments do not lie - digital can handle a lot more information than analog, but unfortunately this capacity is often misused to create an unrealistic view of the event. Stereo 3D localization is created essentially from cues and the way these cues are handled and manipulated differ in both media.
There are several interviews with recording engineers addressing these subjects - I have posted links in past, I will look for them and post again. But some comprehension of the fundamentals (and limitations) of stereo is needed to understand it - most people easily admit that we can have something like 3D in stereo but are not aware how we get it from two channels and two sound sources.
Micro, I think this segues very nicely over to an issue of hot topic over in the Extreme thread.It relates with the amount of information the formats can handle. Instruments do not lie - digital can handle a lot more information than analog, but unfortunately this capacity is often misused to create an unrealistic view of the event. Stereo 3D localization is created essentially from cues and the way these cues are handled and manipulated differ in both media.
So that challenges us even more as audiophiles to question how we are then assessing what is best. Is it just better in partial assessment all the time or do we need to reference more often against the whole as well. Do we have sufficient language let alone guidelines for what is right or what is best.
Is it time we get a better system of assessment of our systems and the criteria we use to make decisions rather than just focusing on buying better (?) gear all the time and chasing more (resolution) more often. Do we need to understand the difference between being particular and being holistic in our assessment.
Do we need to become better tools to not just see where we can have more but also to see when we already have enough. Is it about a greater total balance of things. Do concepts like rightness become more critical when we hit upon the boundaries and perhaps into a great age of information overshoot.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
