What turntables do you use? Pictures would be nice as well :-)
Stylus brush, right. My RS has a bolt that slides along the slot is all. Earlier or later, not sure.
Basis Inspiration w/Super 9 Arm, and Lyra Atlas.
A Linn LP12 is quite rightly an icon of turntable design. I often think of a Porsche 911, whose original basic form has been guarded by its designers through all the decades and at the same time transformed into the future in a modern way.
The history of the Linn LP12 has strong parallels.
It is not easy to find a suitable phono amplifier that also has these ideals.
Under the Linn, the AS Phonolab PRO from www.audiospecials.de takes up the classic form. And at the same time scores with its sophisticated technology.
BTW.;)
It can also serve two LP12s if future expansion requirements should arise.
That wall shelf makes a huge difference as I remember from my LP12 10 years ago. I haven't had a turntable sitting on anything else since. I can't understand why every turntable manufacturer doesn't recommend it when possible.
Garrard 401
SME M2-12R tonearm
Accuphase AC-2 cartridge
Tenuto Gunmetal mat
Custom-made DIY plinth (Baltic Birch Plywood, Maple Burl Veneer, several coats of lacquer).
JR Transrotor Rondino Nero FMD / Kuzma 4point11 / DS Audio W2 (PU and equilizer).
Third table presently in use (family room system):
Technics SP10-MK2
Thomas Schick 12" arm
Denon DL103R PRO (Highphonic) cartridge
Custom plinth (DYI), Baltic Birch Ply, American Redwood Burl veneer, finished in several coats of polyurethane.
Spiral Groove SG 1.2 with Centriod tonearm and Lyra Etna cartridge
Reed 1c with Tru-Glider arm and Hana Umami Red. Just a week old. Both levels of support are made of Richlite Black Diamond (the full stand is the Mosart Audio Rack).
J.A. Michell Orbe, modified with TruePoint Audio suspension (aka Pete’s Pylons) and TruePoint Audio isolation feet (aka Pete’s Pads), Moerch DP8 tonearm, Audio Technica ART9XI (until I trade my Lyra Delos in for a Kleos).
Reactions: No Regrets
Technics SP10-MK2
What SUT do you use with your DL103?
Presently using something I found on-line about five years ago, a custom built unit using a pair of UTC A-12 transformers. The builder added "two independent gain selector switches and a switch for ground lift , with the two separate gain switches the left and right channels are completely independent for less cross talk."
My Avid Acutus Dark with Acoustic Signature 7000 NEO with Van den Hul Colibri Grand Cru
A Transrotor Super Seven. With SME Arm 3009 II Improved.
The pictures were sent to me by community member Björn from Denmark. The Transrotor is from 1993, an heirloom from his father, a watchmaker with a great sense for good design and precision. What was still missing was a phono stage with top quality and matching design. The AS Phonolab from www.audiospecials.de is the perfect match. The TRANSROTOR with the AS Phonolab, both from Germany, will always be an eye-catcher.
Groovemaster
