Hopefully those children of yours will come help polishingnew ss316 Melco plinth ready for polishing
It looks great congratulations. I wonder why the turntable needs a new plinth or why stainless steel?
Not if you had cats![]()
Fortunately they only appeared interested while covered. Then again while listening I was just a few feet awayDo either of those attack the table like it's a prey?
I'd probably need a lot of staples. Should probably make them 316 "marine" stainlessa staple gun would solve the matter....![]()
Congratulation to your The Wand!!!!
Currently I am playing around with The Wand Master tonearm, a lot to learn
(the turntable is a 12" STST Motus II DQ direct drive in the glossy black Corian Plinth)
Looks wonderful. Maybe you would like to try those Shun mook resonators two at the back one in the front. I know it’s recommend to be used just as you placed them but I always find it better sounding two at the back. A little bit smaller and cohesive.My inanimate baby under the kitties. I cobbled most of this together about a dozen years ago from mechanical industrial surplus accumulated in silicon valley over a decade or so prior (mostly Triangle and RA Enterprises). It utilizes a Dover air bearing for virtually friction less spinning. This is a new born photo. The ancillaries have evolved.
Tom:
Thank you for the suggestion. I have tried different orientations w/ them elsewhere. In this application with the plinth weighing only 50lbs, arm pod shy of 30lbs and the platter and bearing north of 100lbs stability dictates two in the front. You've probably experienced that they shouldn't be spread out with their vertexs much greater than 7 or 8 inches. They've actually exited the system and replaced with with second gen Dalby Lignum Vitae Footers.Looks wonderful. Maybe you would like to try those Shun mook resonators two at the back one in the front. I know it’s recommend to be used just as you placed them but I always find it better sounding two at the back. A little bit smaller and cohesive.
