the pump is horrid, and after speaking with SIL in the US (the maker of the pump), i was told that the pump is really too small for the use- that it requires constant duty cycles which is why you are hearing it kick on and kick off. Mine is located in an adjacent utility closet but it's not really far enough away. Scott Markwell offers an upgraded pump, more like a garage sized compressor. If I keep the arm after I move, I will upgrade to a monster compressor and stash it in the outhouse.Luv air bearing arms and loved this table when first saw it in London over a decade ago. Just don't want to deal with the issue of air pumps NO MORE! If you've got a home great but sucks to hear the noise in an apt.
Actually had tried to get it for review back then from Branko in the UK (it wasn't being distributed in the US at that time) but it fell through![]()
SME 30 with 10 inch Da Vinci tone arm (original style, nautical brass). Perfect turntable for those who don't like to mess with turntables.
Not sure cjfrbw,I have a friend down here who needed to chain thise rubber bands every six months or so....
Nice table Carl. When i hear the word "o" ring I can't help but think of Morton Thiokol. Myles, clever idea on compressed air tanks. I could have the hospital supply place drop them off- I wonder what the conversion rate of litre per minute to psi is for life of gas per tank.
This is my front end: SME 30/12, SME V-12, Air Tight Supreme
This is my recently upgraded front end: SME 30/12, SME V-12, Air Tight Supreme. It replaced my former SME 10A with V arm and PC-1 cartridge. It is all sitting on a Vibraplane preloaded with a steel plate ballast weighing 136 lbs, for a total weight of 400 lbs on the top shelf of my DIY rack. Isolation and resolution are superb. This is a very neutral and speed accurate platform for the cartridge.
I did a very slow, deliberate comparison first between the SME 10 and 30/12 using my old SME V arm and PC-1 cartridge. Then I switched arms to the V-12 with the PC-1. Finally, I switched cartridges to the Supreme. I listened to each stage for about 10 days to fully understand what each component contributes to the overall sound.
View attachment 3972View attachment 3973
