For big bucks, buy the Lloyd Cole In New York box set. You get the first 4 albums, the never released album and 2 LP's of B sides and demo's.
Amazon still has copies for reasonable prices.
I found an old-school solidsteel rack that needs a little varnish for my heavy turntable project. Now I just need to get six slate boards or solid wood, and then I can get started.
Someone had stuck car body tape all over it (for damping) and then removed it all with a hot air gun. The adhesive residue is easy to remove with the cleaner and sponge.
Now back to music
Someone had stuck car body tape all over it (for damping) and then removed it all with a hot air gun. The adhesive residue is easy to remove with the cleaner and sponge.View attachment 152539View attachment 152540View attachment 152541
Now back to musicView attachment 152542
I do , johan
The goal is to have everything finished by Christmas, but it will probably be sooner. A minor setback: the Studer motor controller didn't survive. Something new will be designed and built digitally using Arduino.
I do , johan
Okay - that sounds interesting. Are you going to build and design it partly by yourself. This Arduino, I can’t say I have heard of it/them before… but if you are involved, I’m sure it’s top notch..LOL.. !!
