Hi, The REF5SE is everything, but "laid back", I am stunned ... it is so lively sounding in a good way. Perfectly balanced. Also, Nordost kills most of the magic. Yes, it is false speed and worng precision. Soory turntable, but it is true. Try Kubala-Sosna for best result - Elation.
Vess
Agree with Vess. The REF 5 is not laid back. If it is, there is a problem elsewhere in the system, power amp maybe. In my experience, the REF 5 can be downright rowdy with the right material.
Although I would never describe the ref5se as having a laid back dark character, I can see that compared to other preamplifiers that show an incisive, bright and detail oriented sound quality the qualification can make sense. It is all a question of preference.
Perhaps it comes from what you reference is. Mine is cj GAT.
Arc ref5se was indeed relatively laid back, dark in character, base was extended but PRAT was oh so slow. This pre amp ain't no rock n roller, more grand pipe smoking playing jazz etc imo.
Cj GAT has a little mid bass hump which the arc does not have, from the midrange up was clearer, more concise, faster , vocals more up front and can play all types of music.
Don't get me wrong, the ARC was nice but not as good as the more expensive cj
in my system. This was consistent running in single ended with cj amps and balanced using Pass and Momentum amps. Arc pre amp had 690 hours on it and did not change character in the 120 hours I put on it.
BTW, there is no false speed with Valhalla. It is like pure running water IMO, it will sound pure and warm with such equipment and light and bright if the equipment has such tendencies. It is not a cable to sugarcoat anything.
Cheers
