Tonally , yes more like a live event than most…dynamically too with my horns.Lol , so you wanna state that your ...." SET " sounds like a live event ??
Please confirm this is getting funny;
Plenty of my vids up already…go look for them
You’re welcome to come listen for yourselfThese are your words
It is when it comes to preferences. As long as that person acknowledges it sounds different from a live event but says, “I don’t care, I like it better how my stereo does it”…well not much left to discuss.
We should also be mindful that A . Not all manufacturers SE Triode amplifiers invariably measure high THD as compared to other valve based topologies mostly employing NF and GNF, and B . How the SE amplification THD combines with the THD of ones transducer of choice ( more complex than merely the sum of the two ) … Edward De Lima wrote an interesting article on this very subject :
Id say CAT does a better resemblance then lets say New audio frontiers , Alieno , Audionote UK , KONDO and on and on.
Sibatone is a good SET on the right transducer as its more neutral
Most other SET s are highly coloured imo and one can better go for a KT 88 VAC in my view .
To get both Tube Magic and Bass control
I have been hearing SET s at dealers / shows since 2004 , when did you start ??
Same tubes , same sound character , different boxes.
I have owned a Zanden 7000 300B for 2 or 3 years.
I tried 3 different types of 300 B s incl Sophia Electric.
PS The CAT pre amp is the important attribute in the chain
This thread is about whether high power SETs are better then low power ones .
I see no mention of tube types .
Imv they might have more power but the overall sound character stays the same .
Whether one likes it or not and thinks its resembles more the real thing is his / her own opinion .
I m not gone argue that
We found the CAT JL2 Signature to be ultimately inferior to the NAT SE2SE on Apogee Grand panels. CAT is good...for push pull but there are many better (more realistic) sounding SETs. You , like many underplay how harmonically rich live unamplified instruments sound. Do some amps go too far? Yes, but far fewer than sound unnaturally thin.Id say CAT does a better resemblance then lets say New audio frontiers , Alieno , Audionote UK , KONDO and on and on.
You have been extolling the virtues of a particular GM70 amp of late...that qualifies. no?i don’t like high powered myself. But the CAT JL7 reminded me of another high powered KT amp, Ayon Orthos
What speakers did you use for the Zanden? Your own??I have been hearing SET s at dealers / shows since 2004 , when did you start ??
