Which will be your next purchase?
morricab
9,531
5,068
1,228
Switzerland
So they work like the old Exactpower EP15A power conditioners? I have written in the past they were the most intelligently designed existent power conditioners. Two friends still own my old units and are extremely happy with them. Unfortunately Exactpower does not manufacture or service them anymore.
Maybe, not sure how those work
Kingrex
2,934
2,404
350
I really like my lino channel d 3.3 with low resistance cartridges. No nonsense design, very silent, very linear response. It is as close to "what comes in comes out", so it becomes all down to your cartridge selection. I got mono/stereo, absolute polarity and low pass filter options. For me those are the ones to get.
I got the same accessories as well as the 1% resistors.
I am hoping the Wally Tools also get me set up so I extract as much information with less distortions as possible.
Reactions: kodomo
XV-1
3,619
2,629
1,860
Sydney
Sorry, one more question , if I may.
Did they have the spec on your cable?, did you provide it? or did you have to provide your OEM cable for a sample?
Thanks!
Not sure. A member here had his done first. Not sure if he supplied a sample before Revelation Audio made it up.
Revelation audio also has done many Pass labs umbilical chords in the past.
The connectors were exactly the same as the Japanese Phasemation connectors.
Regards
Reactions: Kcin
Kingrex
2,934
2,404
350
I also bought an Audio Quest Angel tonearm cable.
christoph
4,689
4,075
825
Principality of Liechtenstein
Gregadd
1,790
1,850
Metro DC
Maybe a power cord for the XDuoo T Aa=30?
omasciarotte
7
3
10
Saint Paul MN US
www.maat.digital
After reviewing KEF’s tiny and wonderful KC62 sub fro audioXpress, I bought the unit. It’s a perfect complement to my room and the merry–go–round of speaker eval that cycle through our space.
Also, I’m in the middle of a bunch of I²S–equipped gear reviews for AudioKey Reviews, so I purchased a Silver Sonic HDMI 2.1 interconnect from DH Labs. Excellent construction and performance.
tima
5,861
6,935
1,400
the Upper Midwest
Thank you Marty. I’m looking for a light with an incandescent bulb and I can’t have a large base Because of lack of space on my rack’s top shelf. I will probably have a clamp or wall mount.
From years back I have a Littlite that takes an incandescent bulb. It has a small metal weighted base with a dimmer. This was there original product and I would be surprised if it is no longer an option so I dug a little deeper on their storefront. They now have halogen bulbs. There are also surface mount, clip and magnetic base options. Very modular.
Cheaper on A'zon.
Reactions: PeterA
Don Reid
91
94
175
74
When they are finally available I plan to buy a new DEQX Pre-8 preamp/DSP to replace my old DEQX HDP-3. The DSP is an integral part of my fully horn loaded, triamplified DIY speaker system
MichaelHiFi
Active Member
Jan 6, 2022
111
92
35
68
After listening to the Allnic D10000 for the last 2 months, the Allnic D10000 DAC.
Not only does it NOT sound like a DAC, It matches my T2000 30th Anniversary integrated and H5500 perfectly. Brilliant.
Now I need a job :(
