I have no issue with anyone preferring the sound of vintage gear when compared to current offerings. That said I do not believe that the State of The Art of our audio hobby has not progressed over that past 50 years.
It's hard to say... we do have better parts in some ways but some of the highest regarded parts today could have been made decades ago... Jupiter copper foil caps could be made with copper foil, wax and paper, Dueleund resistors are carbon in a paper tube, ole WE wire is still considered to be very good by many people. Tubes are STILL the best amplification devices available.
As far as results go it's hard to argue the new JBL M2 isn't technically superior to most past designs, even recent ones, but IMO that doesn't mean it actually is more fun to listen to or sounds more like real music. In terms of subjective appreciation of recorded music I think maybe we have not made progress in decades...
Sorry, tubes haven't been the best amplification devices in years. You may like how they "sound" but that doesn't that's just your preference.
In some sense tubes are the best amplification devices - they are intrinsically more linear than solid state devices, tube rectifiers are less noisy than semiconductor diodes. Some solid state designers, such as Nelson Pass or John Curls openly refer that their reference are tubes. However they have limitations such as cost, size, reliability, lifetime and power needs that restrict their application.
The new JBL m2 or the older k2 66000 aren't even close to sounding anywhere like good speakers I have heard. There are good JBLs. But not these. I heard a DIY with JBL that was extremely good. I am sure some of the older models or refurbed ones in Japan could be good.
Exactly, the technical advances as far as perfect dispersion and frequency response miss the mark imo... a very simple and efficient speaker + SET amp using top quality parts is subjectively far superior to me and this technology has been around for many decades.
One area I might make exception is for bass reproduction, modern low frequency drivers + DSP and class D amps have major advantages. The typical vintage 15" driver with a light cone and relatively weak motor produces far more distortion than a modern driver with a stiff cone and powerful motor. Also, advances in motor design such as shorting rings to lower inductance make a big difference.
Absolutely. Once I heard my SET Tube Amp in its default configuration, and knew its strengths compared to my SS amp, I knew I needed to give it a proper efficient set of speakers. For now, I only have the Totem Mites to pair with it. They're technically not as efficient as they would need to be for the SET Tube Amp, but I have a configuration where I sit not too far from the speakers and the room dimension in that direction is rather small so the small power output doesn't appear so at all up to quite high volumes.
One great thing and which is in my plans overall is to bi-amp and cross-over all the mid-to-high to the SET Tube Amp, and the lows to a great SS amp (or else a Push-Pull Tube).
I don't cross-over because I do not want to risk losing liveliness of sound.
When it's done well, you lose nothing and gain a lot.
What do you gain?
The 'magic' of Single-Ended Triode Tube Amplification for the mid-to-high (especially the mid as it is known to perform very well there) as well as the power of Great SS or Push-Pull Tube Amps for the low-end.
Oh, I see. I thought you were talking about cross-over benefits for the speakers, but you meant benefits for the amps. Yes, that makes sense.
For my push-pull triode amps of low wattage (15 W/ch) I don't need a crossover, but then the bass of the monitors doesn't go that deep, and the deep bass is provided by the SS driven subwoofer. If I had SET amps I might think about a cut-off filter for the low frequencies, but then these monitors have been repeatedly reported to be SET friendly.
That's a tough one because you'd need a very large cap that will be very expensive to roll off the lows on a speaker level passive... the best way to do it would actually be in the coupling section of your amplifier, which is probably LC coupled and the C value could be reduced to roll off highs, that way there's be little to no sonic penalty, or even an improvement by upgrading the caps. Next best would be a simple line-level cap on the amp input, to size it all you need is the amps input impedance. If you use a nice cap like a Jupiter Copper it wouldn't be very noticeable.
It's only worth considering if you're running into excursion limits on your monitor's woofers, if so it would allow you to play at higher volumes with less distortion.
Yes, as I said I don't think it's necessary with my push-pull amps. The mid-woofers don't seem to move that much, certainly I haven't noticed the wild driver excursions that I saw on my previous monitors with much smaller mid-woofers. In fact, switching from those speakers to the new ones I noticed right away a drastic drop in distortion.
I sit rather nearfield; if sitting further away I might have more concerns. I did measure a drop of 5 dBa volume from 80-90 dBa just a few feet behind my listening position; to compensate for this at that location further back would put a whole lot of energy and stress on both speakers and amps.
(...) I sit rather nearfield; if sitting further away I might have more concerns. (...)
