I have heard ypsilon aelius drive Ultimates and vivid G1, in non show conditions and in another system ABed then with Luxman on G1. The pre does sound good though and could potentially be a final pre if I can get a compare later.
For someone who can get a large room and large speakers, there are very few speakers that can sound good with SET amps - an extremely low number of large horns. Where SET amps work for the average room/budget constrained audiophile is that given he has to compromise on various factors, SETs on speakers like Verity or OTL on quads can be musical on many aspects at low volumes and low budgets.
Many large speakers work very well with SETs. Wilsons and Focal come to mind. Even moderate sized boxes work well from about 90db and up...and quite loud too, not only low volumes or low budgets (last time I checked SETs were not so cheap). We have had very nice success with Thiel CS3.7 and a number of SETs (KR Audio, Cayin 845, Aries Diana, Wall Audio, NAT) and push/pull triode of modest power (VAC 30/30 and Puresound A30). The room was not tiny either and the levels were high much of the time.
But i don't get toy horns and so-called back loaded horns or sensitive boxes.
So you consider the Aries Cerat Symphonia a Toy horn? It uses a backloaded horn woofer...nothing wrong with this concept if executed properly. If the Cessaro Chopin is your reference for this then it is time to change your reference! My Odeons make great bass and so does the Symphonia. These are true horns (the Symphonia is a 3meter long horn...mine are a bit shorter).
SS amps increase the range of speakers that do much more, smoothness and tone of SS can be managed at a price.
I have not heard a SS amp yet that does tone like a good SET...not one. Some hybrids get very close (like my NAT and Ypsilon gear, supposedly the Pathos TT is a sweetheart but only for easy speakers) but I haven't heard a pure SS amp yet that can do what needs to be done. Don't tell me Luxman please...I have heard their best stuff with Vivid Gigyas a few times and, well, no. There are claims that the Pass XA30.8 is the one for tube lovers but I haven't heard it yet so I won't comment. The recent review by Jack Roberts strongly suggested that it was better than the big brother XA60.8s. Power corrupts... .
I am quite certain if I go Apogee in a big room or YG in a small room (now unlikely given how nice Heco is in a small room) it will be SS, mostly class A SS but there are some good AB amps, though all this require money.
I predict the hunt will go on after that...you won't be satisfied. YG in a small room would work fine with 20-30 watts of SET power. Heco even better. If I was going to do big Apogees in a big room then I would think about Ypsilon Aelius, NAT Transmitter, or CAT JL2 Signature. If I had the serious coin to drop I would consider the Ypsilon big hybrid SET monos. I think Ayon Vulcan Evo or another parallel SET with about 40-60 watts would do the trick (Absolare monos for example?). The big Apogees, except for the original Full-range, are not so hard to drive.
Sure, if I go trio, universum, WE, it will be SET. Amps cannot make up at all for the sound once the speaker is compromised. If anything amp ideology can screw up the sound. Better to spend on a good TT
Amps can make up a lot on a system...they can turn so-so speakers into quite good sound...I have heard this many times. What I have also heard is the COMPLETE destruction of the sound with poor amps...even with the fnest speakers...this is the number one problem with show sound, IMO. Bad electronics ruining the sound...not the room.
Recently, I was at a show only a few hundred meters from my home and there was a room with the Vandersteen Treo speaker driven by an all Brinkmann setup. It sounded wonderful...Now the new DAC is really good and a hybrid and the preamp is a hybrid but the amps are no feedback SS amps. It didn't have the depth of tone of a good SET but the surface was mighty nice. I have heard the same speaker with different electronics the year before and it sucked. It was the same room and same setup (they always for some reason get the same room every year). Interestingly, two years before it was also great with all Brinkmann again.
I heard the same thing in Munich. One year they had the Vandersteen 7 with Brinkmann amps...great. The next year with their own branded amp (not sure who actually made it) sucked. I have heard this so many times I have lost count. People write off a speaker but they haven't heard it's best.
Sorry this gets repeated
d
