I would try a free RCA plug if available.
Yes!
You can connect it to any unused socket. For example to a spdif in or output, or the analogue rca output if you use your dac’s balanced outputs, or to the XLR connector if you use it the other way around.
Typically they ship within a week.
As every system can sound completely different even with the same components I would go for personal preference. If you had to exchange a system component right now, would you exchange it for one with a higher apparent resolution (silver/gold) or a fuller/darker sounding one (copper). As most people end up buying more then one there’s also the option to mix & match.
Not trying to be offensive, but please don't use the word "then" instead of than. It does not sound right.
I just added the Synergistic Research Active Ground Block. Surprised how much better it is over the passive ground block they sell which I also liked.
Grounding is very important.
Since we are talking DACs, add a Synergistic Tranquility Base under your Lampi. Makes a big difference. I put one under my PS Audio DirectStream DAC and clarity improved a surprising amount.
Assuming they are discontinued do you mind if I ask why you stopped making them?
Hi Emile,
Thanks for getting back to me.
I guess I'll see if I can pick up a pre-loved one.
Cheers,
Alan
If the product is good, they would keep making them and even make improvements to the product. Their response of "economically unviable" is a deceptive way of saying the product is a fraud. I wish they were more honest.
I was considering the purchase of one of these Setchis. When a manufacturer ducks out and stops support of his product, it makes me wonder why. A poor generalized reason does not help at all. A better explanation is deserving to us.
Hello Alan,
They have become economically unviable.
Where did Emile say he wasn’t supporting the product? He didn’t. He said he wasn’t making any more.
If you are going to call someone a fraud you should at least have your facts straight and some real proof.
If you stated your question in a decent manner like this it would be totally fine and you probably would have received a more detailed answer.
Calling someone a fraud without physical proof is called slander and is punishable in a court of law.
