ZYX Ultimate Dynamic with Accuphase C47 without Step-Up ?
hongkongfoufou
531
238
153
Hello,
Someone knows if I can connect ZYX Ultimate Dynamic cartridge with Accuphase C47 without an additional Step-Up ?
Thank you very much
Ultimate DYNAMIC
Technical Data
TypeMoving Coil (Dynamic)
“REAL STEREO” Generator System
Cryogenic TreatmentTemperature: -196 ? (-320?F)
Output Voltage0.15mV (3.54cm/sec, 1kHz)
Frequency Response
±1dB
10 Hz - 100 kHz
20 Hz - 20 kHz
Channel Separation? 30dB ? 1kHz ?
Channel Balance? 0.5dB ? 1kHz ?
Recommended Tracking Force2.0gm ? 20 ?C-25 ?C ?
Tracking Force Range1.7gm - 2.5gm
Trackability?60?m /2.0gm
EQ Compliancehorizontal
vertical
15×10-6cm/dyne
12×10-6cm/dyne
Internal Impedance12 ?
Load Impedance? 100?
Coil Wire6N OFC Crystal Copper?0.035mm
Cantilever MaterialC-1000 Composite Carbon ?0.30mm
StylusMicro-Ridge Solid Diamond?0.1mm
Contact Radius, Life Time3?m×60?m, 2000Hour/2.0gm
Output Terminals?1.25mm K18 Solid Gold ?EIA?
Terminal BoardComposite Carbon Plate
Dimensions16.8mm(W)×19.0mm(L)×16.5mm(H)
Net Weight6.8gm(TB2 pre-mounted), 8.0gm(SB2)
Agree
70db gain is enough for .15 mv cartridge
Hello all,
Thank you very much for your help.
Best regards
Thanh-Binh
Reactions: Nascimento
Who can say if the differences between the Zyx Ultimate Dynamic and Zyx Ultimate 4D is justified ?
Actually it’s real output is 0.21mV not 0.15. Anyway 70dB would be enough (gain selector on). Normally ZYX cartridges like high loading so 300ohm seems like a good starting point.
Reactions: hongkongfoufou
Hello, thank you!
So I have choosen Zyx Ultimate 4D with 0.24 mV...SB2...Cu.
Reactions: XV-1
