One my friend has Atlas and Erodion red and prefer listen with Erodion
when I tried Erodion Evo with MM input of my CH, I found more stage, more body and more dynamic, was a fantastic sound, only very little less transparent on high, but this is normal
If you contact our distributor in the US, Audioquest, I am sure that you will receive an answer.
That’s why a SUT should have a non-detachable cable with the same material that transformers are wound IMHO.the SUT cable is critical too
Agree. In my opinion, the entire chain from cartridge clips to MM phono (headshell leads, inner cable, tonearm cable, SUT, SUT cable) should be made from the same material or cable.the whole chain from cart to riaa ideally should have been soldered or even better wirewrapped
If it’s right, you don’t need flexibility. and bye-bye to flexibility......![]()
