Hey Milan,Yes you put that one on the map for me with a earlier post, i have been looking for a used one since, the Burmester 100 is on my radar too, on Ked's recommendation, they can occasionally be bought for about € 10 K, as can the Gryphon Legato Legacy![]()
I had the Burmester 100 here prior to my Momentum phono. It was really really good sounding. I had true thoughts about to invest in it, as at the time the Momentum seemed out of reach. The Burmester 100 had close to the sound I was looking for and is really high quality both soundwise and build quality. I would definitely recommend it, or at least give it a try at your place… it would not hurt anyway.
For me in the end… I choosed the Momentum as the best choice for my setup and to match the rest of my gear. If you want to give your heavy wallet some air, maybe the Momentum is something for you as well. At least there’s no tubes inside
/ Jk
