Pure Audio Project upgrades and tweaks
Starting this thread to discuss Pure Audio Project open baffle speakers, upgrades and tweaks. @Kingrex - if you have had both the horns and Coax10, I would be interested in hearing how they compare. And I copied your earlier post below.
What cables upgrades did you use? And can you share a picture of where you located the crossover? Is it attached to something else, or sitting on the floor? I was wondering about the height of the midrange/tweeter and if I should rake the front up. My system will be the Trio15 Coax10, Playback Designs MPS-8 source and Pass Int-25 amp. I'm still waiting for my walnut baffles to ship from RJ Millworkers.
You have to get the updated speaker cables. Its critical.
And , you have to separate the crossover from the frame. Again critical.
If the crossover is touching the frame, the music is very smeared from the intense physical vibration.
If you use stock, instead of upgraded cables, you loose life, air and bass. Less coherent.
The speaker is very good with these tweeks. You don't need to futz with any caps or reaistors with the Coax crossover.
You need to be patient. They take 500 hours like any speaker to break in. 2000 or a year to really be there. I actually put my coax in the basement connected to a class D amp and laptop for week and let it rip sitting on the floor. I would go dowm 3 or 4 times a day to switxh the album and volume.
Also, mine sit on a 9 inch tall very heavy block of wood that sits on fiberglass insulation. A rug would also work. Massive improvement in bass. Just shocking. And, it raises the center of the coax much closer to ear height. Otherwise its too low and like sitting in a balcony.
The fabric over the top keeps the sun from striking the driver. That is all its for.
Reactions: yann09
Yes take it bit by bit, and if it doesn't sound better, reverse the work.
The Quintet15s are a superb speaker, I can see it will never sell them! As stock they are already way beyond their price point, I would say 3x beyond at least. A few tweaks here and there to suit my taste, and it gets to another level in my room. The room and system all affect things of course. I also use 2 x JL Audio subs, though without them they sound wideband, I have them set very subtle.
Oui, allez-y petit à petit, et si ça ne sonne pas mieux, inversez le travail.
Les Quintet15 sont d'excellentes enceintes, je vois bien qu'elles ne se vendront jamais ! En stock, elles sont déjà bien au-dessus de leur prix, je dirais même trois fois plus cher. Quelques ajustements ici et là pour les adapter à mes goûts, et elles atteignent un niveau supérieur dans ma pièce. La pièce et le système ont bien sûr une influence. J'utilise également deux caissons de basses JL Audio, mais sans eux, le son est large bande, je les ai réglés très subtilement.
Oui, je vais le faire très progressivement
J'utilise le boîtier Rel32 et j'en suis satisfait. Il existe probablement mieux, mais il est difficile d'essayer différentes marques chez moi.
J'ai donc dû choisir une marque.
J'ai une question, qui sera probablement très stupide, mais ce type d'enceinte est nouveau pour moi.
Pourquoi les câbles des haut-parleurs ne vont-ils pas directement du filtre aux 4 woofers ?
Si je devais faire passer tous les câbles directement depuis le verre, y aurait-il un problème ?
Replace the stock cables. Stock are very limiting in performance. The upgrade cables through PAP are very good. The foil I noted is similar to the upgrade cables. But its not as good. The cables are very audible. Its not easy to select the correct ones. I still have work to do with mine.
I have heard the open baffle speakers Rhapsody carries. They are in a concrete frame. They are very similar. PAP definitely rival the performance. I was mulling how I could make a concrete frame. The difference is in the air and space. The Rhapsody speaker is more controlled. Thats the very dense frame material. It may be the concrete and rebar could be a simple side brace and the existing PAP faces are bolted to the concrete. Easy, inexpensive and possibly very effective.
I also thought about getting the counter top material from Home Depot. The wood tops they make. The Maple top may work well. Its strips of glued 1.5 inch material. Its about $200 for a piece that would work for a single Trio 15. Alll you have to do is route the holes and make a floor brace to hold it upright.
I'm going to do it very gradually
I use the Rel32 subwoofer and I'm happy with it. There are probably better out there, but it's difficult to try out different brands at home.
So I had to choose a brand.
I have a question, which will probably be very stupid, but this type of speaker is new to me.
Why don't the speaker cables go directly from the crossover to the 4 woofers?
If I had to run all the cables directly from the glass, would there be a problem?
Thank you for your reply.
I had the enc k2 S9500 from JBL
CE FUT very good speakers.
The criticism for me was the concrete base.
Too heavy
And every time I wanted to adjust the positioning of the speaker
I damaged the tiles every time I moved them.
Even with skids under the concrete bases to help move the speaker, it remained too heavy to move.
Great thread!
I’ve done some mods to my PAP Quintets 1.6 Voxativ
I have them sitting on 3” butcher block. I have Wave Kinetics 2NS isolators Eden Sound brass footers go into the 2NS.
I used Isodamp along the frame where the baffle attaches to the baffle. I also added washers to the bolts so I could tighten the baffle to the frame tighter. The bolts were sinking into the wood so the oversized washer fixed that issue. I added washers and lock washers on the back.
This increased the resolution significantly. Everything was more clear and precise while still maintaining the rich enveloping sound.
I had Jonny from Snake River Audio make me custom cables and jumpers for the wiring.
I rebuild the crossover using an air-core inductor. I needed to go to a 10 AWG wire to keep the resistance as close to possible as the stock inductor. I also added Dave Slagle’s Speakerformer to attenuate the Voxativ driver. I’m just about to solder it in and mount it.
Adding No-Rez to the metal frame on the inside added a nice step up in overall resolution as well. Mids and highs are so clear while the bass is full and tight.
I'm thinking I'm going to cut a piece of wood to cover the hole where the crossover used to fit.
My goal with my system is to sit down and get lost in the music. I have achieved this. Have the clarity to hear all the subtle detail and nuance. The bass to lay down a good foundation. Finally the holographic presentation that has gotten to the hallucinogenic level. Some days it’s like being in a lucid dream.
My dad was telling me about an intimate concert he went to. There was one musician playing the sitar in the center of the audience encircling him. He said after a few minutes he closed his eyes, a few minutes later he was getting visions in his mind that played off of the music. This is the hallucination or psychedelic experience I’m experiencing.
Great thread!
Hello
I hadn't taken a good look at your photos.
I see the insulation you applied along the frame.
It gave me the idea of finding cork sheets between 2 and 3 millimetres thick.
So I'm going to put some between all the joints in the frame.
I'm going away for 3 weeks, so I'll do it when I get back and let you know if it's had a beneficial effect.
I used NoRez for one side of the frame.
I did try with both sides covered with NoRez and found I preferred only one side covered. If it wasn’t such a chore to reapply and remove the NoRez I might try again now that I’ve changed a few things. I’m also so happy with the sound I’m getting I don’t want to mess with anything major. Only thing that is changing in the near future is I’m getting some custom power supplies from Zayin audio for the field coils. After that I don’t want to mess with anything.
Let us know how the cork between the joints works. I used an impact driver when I put my frame together so it’s extremely tight.
I'm going to test it when I get back
In 3 weeks.
Thanks for the link to your insulation.
If cork doesn't work I'll do what you did with your insulation.
I've had my pair of PAPs for a while now
So I've got a lot of things to do to improve it.
For the moment I have not changed anything except that I moved the filter away from the base and I found the message clearer.
Thank you to all those who exchange on this site, it helps.
Reactions: GroovySauce
In 3 weeks.
Hello
Just to keep you informed of the test I have to do with the cork insulation.
For the moment I had to send back my Voxativ because there was a defect on one of the 2 loudspeakers.
Pure Audio Project was very efficient in taking care of the problem under warranty.
I'm due to receive a new pair on 21 July.
So I won't be able to test the cork insulation straight away, as I'll have to wait for the break-in period to get used to it.
At the moment I haven't had the Voxativs on my speakers for 3 weeks.
See you soon for more information
