Videos - oomph, tympani, menace, power
He did not voice his opinion at the time.
That may be true I can’t remember. My point is that he would be able to make an assessment on the quality of which phone is more accurate. People use these system videos for different purposes. I use them as a tool and I listen for particular characteristics on the video but realize they don’t convey everything accurately. They are also used for fun and sharing. My question remains. I suspect some would prefer the phone that is more accurate and others would prefer the phone that sounds more pleasing to them. They may or may not be the same.
I was curious to find out how my small speakers could handle the Bartok piece that Tima filmed.
They struggle a little, but I enjoyed listening anyhow.
My amp has limited power, which does not affect dynamics (in my humble opinion) but you simply cannot push it beyond a certain volume level. This was close to max volume. The speakers probably distort at those high volumes anyway...and my phone as well!
Bartók's 'Concerto for Orchestra' is perhaps his most accessible work. (!) It was commissioned to him toward the end of WWII by conductor Serge Koussevitzky while Bartok lay in a hospital bed suffering from leukemia. The work revived him for a while but a year later he succumbed. This Concerto is in five movements and as best I can tell, none of them relate to the others. The 4th movement is, imo, one of the composer's most melodic pieces.
Here is the 1st movement. It features a particular Bartókian style called 'night music' From my review of his Piano Concertos, most of this still holds for the piece at hand: "Bartók’s orchestrations feature percussion, brass and woodwinds, while relying on strings for texture and atmosphere. Each piano piece includes instances of Bartók’s famous "night music," a sound portrayal he often used in slower movements. Instead of harmony and melodic development, Bartók delivered his interpretations of nocturnal sounds from animals and insects, often using drum and cymbal taps, strikes and splashes. The meaning of these concertos always seems just around the corner, just out of reach. Nonetheless, for those willing to explore, each work offers wonder, obvious genius, and a celebration of the sheer physicality of sound."
If Stravinsky is a rhythmic devil, Bartok is a rhythmic dervish. Note the continually varying time changes in this piece. While its intro section is slow semi-brooding, overall, from Andante to Allegro Vivace, it can be as feral as some of Bartók's earlier works.
Here with the Lamm M1.2 monoblocks.
One of the best from The Original Source series by Deutsche Grammophon
Bartok 'Concerto for Orchestra' 1st Mvmnt (Introduzione) Andante Non Troppo – Allegro Vivace
Rafael Kubelik/Boston Symphony Orchestra
DG TOS 2530 479
Tim, I like your notes on the music and also this video. The presentation comes across as a whole, very coherent. Great balance and dynamics. "The sheer physicality of sound" comes across well over your video.
Reactions: tima
This music kinda latched on to me. Mid-twentieth Century is perhaps as modern as I've done. Thank you for viewing and your comments. There is more interesting Bartok to be had. I think these home videos are important because they are not abstract connections to equipment but to real people with a passion for music in their home. They are an opportunity for exposure to music one has not heard. They keep alive the the reason some of us are audiophiles.
Reactions: wil and PeterA
Here is 4th movement of Dimitri Shostakovich's Symphony Nr.5 with Leonard Bernstein and the NY Philharmonic. It was recorded in Boston Symphony Hall. This happened shortly after the conductor and orchestra performed it in the Soviet Union with Shostakovich himself attending. Shosty liked it.
The work is complex with lots of emotional tension, bleakness, references to Russian folk dances, it is both searing and elegiac.
The 4th movement is triumphant, incandescent and victorious. "The resounding march that ends the movement (~08:12) represents the triumph of evil over good. The apparent optimism of the concluding pages is, as one colleague of the composer put it, no more than the forced smile of a torture victim as he is being stretched on the rack." ref
Shostakovich had angered the Soviet Hierarchy, particularly Stalin, with earlier works including his opera Lady McBeth (quite the story there.) The reality of living under Soviet System coupled with the composer's desire to be Russian and stay in Russia led to his recognition that he somehow must appease the hierarchy. Here was his response to return to the System's good graces. The audience loved it and Stalin approved. Critics debate whether the ending is truly victorious or hollow under the covers -- a tacit mocking of prior criticism.
To understand Shostakovich is partly to understand Russian history under the Soviets.
Audio cat Finzi voices his approval by not slapping his tail on the carpet.
I love seeing Finzi enjoying your music with you :) !
Best wishes,
Don
Reactions: tima
Here is an excerpt from Witches Brew on vinyl being played on my trusty old Linn LP12/Naim Aro tonearm/Benz Ruby Zebrawood S-Class moving coil cartridge into my all vacuum tubed Wavestream Kinetics Deluxe Phono Reference Level 5.1 with outboard power supply; First Sound Presence Audio dual mono vacuum tube line stage; Single Ended 845 vacuum tube power amplifier powering my Dunlavy SCIV Signature speakers.
Best wishes,
Don
Mahler 6th Symphony
1st Movement
A-minor.
Mahler instructs the conductor: "Allegro Energico, Ma Non Troppo. Heftig, Aber Markig",
which means 'Quick with Energy but not too much. Intense but Pithy.' Leaving a lot of room for interpretation.
The work has the nickname "Tragische" (Tragedy). Exactly why is unclear. From what I read, the nickname results from interpreting the work in terms of Mahler's life, which imo is but one approach. That one likely comes from the words of Mahler's (ultimately unfaithful) wife Alma who wrote "“in the last movement, Mahler described himself and his downfall, or as he later said, that of his hero. ‘It is the hero on whom fall three blows of fate, the last of which fells him, as a tree is felled.’ Those were his words.”" The blows of fate could mean the death of Mahler's parents, the suicide of his brother and the turbulence of his marriage. Then there is his having heart disease. Bruno Walter claimed Mahler himself called it 'his Tragic Symphony'.
The Fourth Movment includes the famous Hammer Blows, originally three later reduced to two strikes of a large/giant hammer on something suitable to making a loud thud sound. Not a standardized percussion instrument, most orchestra make their own hammer instrument. The Hammer Blows get interepreted as the blows of fate.
On the other hand ... the First Movement is indeed energetic and martial with its snare drums. I don't see it as tragic in the least. Mahler wrote it out in the country in an idyllic setting and claimed to be happy during that time. We hear cow bells in the background (11:10, also in the Fourth Movement) which made me think 'pastoral' (but it is wholly unlike Beethoven's 6th which has the nickname Pastoral'.)
Lot's of interesting percussion during the First Movement and throughout. Orchestration calls for 6 timpani, bass drum, 2 snare drums, suspended and crash cymbals, triangles, cowbells, two tam-tams, rute (a bunch of sticks used to strike on the bass drum case), bells, glockenspiel, xylophone and The Hammer. The Sixth has the largest non-choral orchestration of all Mahler symphonies.
However we characterize Mahler's Sixth, it is complex and imo makes for an entertaining listen. Mahler at the top of his game.
Herbert van Karajan, Berlin Philharmonic
DG 2707 106
Recorded 1978
This 2025 release is from Deutsche Grammophon's 'The Original Source series'
AAA. from original 8-track tape. Imo, one of the better TOS recordings.
JBL M9500, Lamm M1.2, vdH Colibri MS
