LampizatOr Horizon - Tube Rolling Paradise
I also run my 727 preamp to Gyphon Mephisto monoblocks balanced w XLR. But in my case, I have no choice as the Mephistos only have a balanced input, no RCA. I'd like to do the same experiment, but cannot. Also, since this is SS gear, I think the difference, if there is one, may not be as easy to distinguish. But for a 1 m run between the H360 and the 727, it was an easy experiment to do and the results were easy to hear. It's all good if it makes you smile.
We both have the 727, you have the Gryphon Solo's, me the Mephisto, we both have the 360, I also run Balanced to the Mephisto. I tried doing exactly as you suggested, Cardas Clear Beyond XLR, and RCA Both 1 meter. I also have 1 meter Clear Beyond XLR between the 360 and Solution 727. I always prefer Balanced on the H/360. What I didn't do with this exercise in Single Ended is keep the right bank open.
One caveat; You should not have both SE and XLR coming out of the 360 (outputs) at the same time. I thought the same. Apparently they are NOT independent of each other...
I totally agree. It's never both cables from preamp to amp but either SE or XLR
in my amp manual it says in Bold letters never to have both cables into the amp
you also need to try it with the right bank of tubes removed
Agreed, but I was referring to the 360. Either XLR from the 360 to the preamplifier or Single Ended but never both at the same time. I assumed the changing of the inputs in the pre would mitigate this. This is not the case, the output of the 360 is either XLR or SE but shouldn't be connected at the same time. As I mentioned they are not independent of each other...
Reactions: Steve Williams
Hey Marty (our typical Canadian salutation). Thank you for going above and beyond, in both the steps you took to compare SE vs. Balanced operation of the H360 in your system and to explain in simple and cogent terms why SE puts a bigger smile on your face.
I never considered keeping in place my XLR cables between my H360 and preamp and using them as essentially SE wire by simply removing the right bank of tubes. I love elegant solutions. I'll give that a try and report my findings to the group. Kudos, Marty!
Steve, thanks for sharing Lukasz' tip that the right bank pentodes can be left open as a simple way to assess SE operation/sonics. Another reason (in a long list of things) to love the Horizon - for not only it's incredible performance, but its versatility too.
Same here, I have 3 different Lampi DACs at home right now and all of them are performing flawlessly with TP adapters. Also worth mentioning that all of them are really quiet in terms of transformer noise while using rectifiers in TP adapters.
I think our rolling community is quite big, so such unlucky events are not something we can fully avoid, sadly so called NOS tubes are in reality nothing but a roulette.
Hope everything will be resolved in a healthy manner.
It's been several weeks since I have posted about my Horizon experience. This transcends seeking out the vintage tubes and paying a fortune but I thought would interest Horizon owners who need adapters for their tubes to play in the Horizon or in any Lampizator for that matter
As the saying goes, "everything matters". All I can say is that the TP adaptors by Laszlo and Tibor with associated Star grounding cable are an absolute must. in fact you'll think I'm drinking the Kool Aid when I tell say I'm gobsmacked as to how good these adapters make my system sound.
Laslo is making these now in a standard edition and a Special Edition. If you can spring for the Special Edition Adapter along with his Special Edition Star Grounding Wires do it. They are truly that good. I have adaptors for the Valvo G2504 and Telefunken RGN2004 as well as the TFKN c3g all 3 star grounded to the rear grounding post on the Horizon
Up until today I have been waiting for the final piece to my TP adapter collection ad that was the adapter for my SRS551. I ordered a pair of these in the Special Edition as as well as the Special Edition Star grounding wire. These arrived today from the beautiful city of Budapest and as always impeccably wrapped by Laszlo . Laszlo promised e I would be in for a surprise with these adaptors as they bring out the best in the tubes
It was an absolute understatement as it was listening to a major upgrade in my system as the dynamics were not only there but were there in a tight, articulate fashion. The snap of the stick on the drum skin will give you goose bumps and the sound of the guitar strings was really unexpected. I played my typical demo disc and every song played seemed to bring me closer to the music that ever before
It really is fortuitous that we tube whacko's here at WBF have the good fortune of having Laszlo and Tibor not only provide us with exotic and beautiful tubes and now with the TP Adapters Special Edition and Special Edition ground wire,
I have only listened for a few hours today but enough to know that these adapters are a must have Ultimate Tweak if you are using tubes that need adaptors for your Lampi. Laszlo told me they will sound even better with some hours of burn in. They really are also a work of art and a thing of beauty that complements the look of your Lapi
These adapters are so good that I told Laszlo he should consider making all the standard adapters and he would be rich. Much to his credit, he said he loves his Lampi community and for the moment is enjoying making these only for the tubes we have bee getting from him
Below are some photos
How can I purchase a TP adapter?
Paul
Ah, we have now moved from tube rolling to adaptor rolling! Perhaps Lampi should cash in on this trend with a new DAC called ARP!
Reactions: Justjazz
Paul
Feel free to buy one of those cheap Chinese adapters from eBay but if you want reliability and excellent sound you reach out to Laszlo and buy one of his adapters. They are precision made and beautiful to behold but it’s all about the sound and IMO you get the best from his TP adapters
Reactions: Blake
TP adapters are the best and he is a great guy!
Reactions: Blake
100 % agree.
The best adapters you can find and you will not find a better person to buy from.
If you own a Lampi and Exotic NOS tubes, I believe the TP adapters are mandatory and not optional !!
and lets not forget his Star grounding for the Lampt tubes...also mandatory IMHO
Agreed. Extremely pleased with the sonic improvement that @takacs75 's adapters and grounding made to the already stellar Horizon and Horizon360. Highly recommended!
Reactions: 2ndLiner
The Horizon and the H360 are stellar performers right from the factory. As I said in a prior post, tube rolling affords owners the ability to customize the core sound of the DAC at the edges of its sonic envelope. One doesn't need to, but one can - if positive results are achieved, as with any audio tweaking. However, if you take that step with this or any other Lampizator DAC, then IMHO the "paradise" from tube rolling will not be fully realized without the use of TP adaptors and star- ground harness.
Prior to Lazslo's creations, I tried two other custom adaptors. Neither rendered the black background and tonal control and accuracy that come from the TP adapters, especially when you have a 4V rectifier that requires a step-down resistor. Besides, they add to the retro-meets-modern look of Lukasz's Horizon design. All other adaptors cheapen that look.
There is only one other tweak that has added more sonic magic to my H360 than NOS tubes with TP adaptors and that is the Vertere Pulse HB-S power cable. It's far more than a tweak, actually. I've been trying various power cords with the Horizon and H360 (SR Galileo, SR Atmosphere Level 3 Digital, Shunyata, Odin 2, etc.) for the last couple of years. None have come close to such a natural match. All the goodness that Lukasz has designed into the H360 is accentuated by the HB-S, moving it across the imaginary "analog" line in the digital world. The sound has even less quantization distortion on the front and trailing transients than Lukasz has engineered out of the digital conversion side of his flagship DAC. That quality comes through in spades on piano, woodwind instruments, acoustic strings and human voice. The match is like the Duport Stradivarius played with the Francois Xavier Tourte bow. Each were made to be play with the other.
So many options. So much fun. My only suggestion is that at some point one should say I’m here. I’m happy and climb out of that rabbit hole otherwise you’ll forever be chasing your tail
Tube collecting, like any other addictive hobby, has no end but you run out of space and time. I decided to put a stop to my Lampi tube rolling because there are only a tiny few closets in my house that I can devote to storing tubes! Besides I have to store tubes for my SETs and pentode tubes for my ARC amplifiers. It’s a real rabbit hole of super specialized gear. I got a CJ GAT S2 preamp a few years back. Takes just two 6922 tubes. You’d think there’s not much scope for tube rolling with the GAT. You’d be wrong. Before long I amassed ECC88’s, ECC188’s, exotic Siemens Rohre tubes, Philips tubes, etc. You could fill a garage with just 6922 variants if you tried! I try to limit this insanity by imposing a strict limit on how much I listen to my tube gear. Now that summer is here, I’m largely using solid state gear for the most part.
For people who have had both the 2504 solid plate and the 2004 mesh plate rectifiers in the Horizon can you describe the difference in sound between them?
I have and tried both in my H360, though I recently had to cycled both rectifiers again after installing the CAD GC1.1. I connected one lead of the GC 1.1 to the ground post of my Shunyata Denali power conditioner, which supplies power to the H360 and my Oladra. The other GC1.1 lead is connected into a spare USB port in my Oladra (server/streamers are usually the biggest generators of digital noise). I keep the digital power side of my system separate from the analog side.
The reason for trying both rectifiers after the GC1.1 install is because I thought the 2504 solid plate was a bit more linear in its power control, making a slightly "blacker" or "quieter" backdrop. My system is very quiet but the GC1.1 has really made the background absolutely silent. It allows more detail and nuance to emerge from the darkness.
Anyway, getting back to your question. I now find the 2504 and 2004 equally linear in their conversion and power regulation (i.e. both provide equally quiet backdrops). I should add briefly that the TP Adapters helped with that too, in the quest to remove digital noise from my system (as noted in my post above). It's clear (no pun intended) that Lukasz has significantly reduced digital hash in his H360 design relative to the H1 and Pacific.
So, how do the two rectifiers differ IMO and in my system? The 2504 provides a bit more speed and snap to things (notably the leading edges of transients) and additional clarity to the sonics. Bass notes with the 2504 have a similar quality, with slightly more front punch. The 2004 mesh, by contrast, has a bit more bloom (i.e. warmth), evident in the duration of the sustain in trailing edges of voices and woodwind instruments, and slightly more ethereal/atmospheric elements in musical pieces that have introduced an echo affect or are recorded in venues which provide it naturally. Voices have a bit more mid-range heft and bass has slighly more plump.
It's important to note that both are excellent rectifiers in my H360 and these differences are subtle, but sufficiently distinct to separate the two tubes from one another. I should also mention that I used both the 2504 and 2004 in my H1 as well and my comments above apply to both the H360 and H1.
My test tracks include "Grandmama's Blues" by Cyrus Chestnut from Earth Stories, to assess transient shifts and clarity; "Lowdown" (Unplugged) by Boz Scaggs from the Hi-Res edition of Fade Into the Light and "Track 12" from Shelby Lynne's Suit Yourself, to assess vocals; and "Stilhed (Sunget Af Frida Hilarius)" by Mike Sheridan's from I Syv Sind and "Patience" by Areni Agbabian from Bloom to assess blackness, inner detail and sustain.
I agree. Both are excellent. The mesh RGN 2094 is airy and a little smoother sound. The 23504 solid plate is like an RGN 2004 on steroids. More meat on the bone. Better dynamics. Love them both and have 3 backups of each. Lately however I have switched to Valvo AZ12. Far less money and is right in the middle of the TFKN RGN 2004 and VALVO G2504
Reactions: ctydwn
