Holbo mk2 Airbearing Turntable System
The latest incarnation of the Holbo Airbearing Turntable, which added a clamp to the package, is very reasonably priced - 4990 € for what you get, which is a fully air powered design of the sort that very few make now or ever. It’s nicely put together and well built, all it really needs is a dust cover. The fact that it tracks the vinyl in the same way as the cutting head on a mastering lathe gives it a distinct advantage and one that the results live up to, I recommend you have a listen.
This looks like a wonderful turntable at a very, very reasonable price. I, personally, am a fan of linear-tracking tonearms.
Reactions: hb22
Hello Bostjan,
With which cartridges do you have experience on your turntable?
Hello Bostjan,
VDH Colibri XGW Master Signature , Benz Micro LP-S , Benz Micro Ruby Air3 , Kiseki Blue, Goldring Elite , Denon DL103R....They all work very well, but of course there are differences.
That's a very nice and wide variety of cartridges with which to have experience on your turntable!
May I ask what is the horizontal effective mass of the arm? Also, by looking at the photos, I believe the arm is a high pressure (at least relatively) design, how much air pressure does it need ?
Thanks
Reactions: mtemur and hb22
Thanks
48 grams whole tonearm with Denon dl103r and counterweight which can carry a cartridge up to 13 grams.On request, there is also a heavier counterweight that can carry cartridges up to 20 grams.Denon weighs approx. 10 grams with screws and plastic protection.
The Holbo mk2 airpump has a pressure of 0.3bar and can carry air to the plater and tonearm for 3 turntables, so it uses very little air due to its extremely small tolerances.
Reactions: thekong
Unfortunately that doesn’t answer @thekong ’s question, effective mass of the tonearm?
He is probably satisfied with the answer; if not, he will ask again.
Probably you’re right but since he brought up the subject I can’t help but wonder what is the effective mass of the tonearm on your turntable?
What’s more, the tonearm is pure genius in terms of simplicity and super-effectiveness. It’s a suitable support for any quality cartridge, no matter the price. As provided for review, the Kiseki Blue was a befittingly high performer. Of course, your mileage will vary depending on your cartridge of choice while further variables will be introduced via the downstream phono stage and accompanying electronics and loudspeakers. Oh, and did I mention that ultra-quiet air pump system? Wow! I challenge you to detect its presence from a meter or so away in a quiet room.
The Holbo Airbearing Turntable MK2 is a cement-solid platform for wringing the most out of your vinyl collection. This is, truly, an outstanding vinyl-spinning system.
… Edgar Kramer
Reactions: mtemur
I was blown away by its performance, its simplicity, its virtually silent operation, and most of all, the way it can connect with the music.
With products like the HOLBO Airberaing Turntable System MK2, the analog is far on the safe side and far from relinquishing.
For what it represents price-wise and performance-wise, I am more than happy to give the HOLBO Airberaing Turntable System MK2 a double-decker Mono and Stereo award in the form of Highly Recommended Product and Best Buy Awards. • Matej Isak
Reactions: mtemur
Well, we quickly summarized why we are conducting this test, and when we finally got to the specific subject, I can safely say that the Holbo Airbearing Turntable System, which comes from nearby Slovenia, is one of the best turntables I have ever heard, and as I mentioned at the beginning, there were quite a few of them that I have listened to, if not owned.holbo remusic.jpg
