I prefer the metal dome tweeter in the X2's as compared to the XLF's. The sound much more natural to me. I am not saying that the X2's are better speakers because I do believe that the XLF handle the mid range better and the ability of swapping from front to rear porting makes them easier to dial into any room.
Their are very few people who have been fortunate to compare the X2's and XLF's side by side. Most dealers will not stock both and many of us could not fit both into our listening rooms.
In my mind MBL has the best sounding high end of any speaker.
Fig.5 MBL Radialstrahler 101E Mk.II, spatially averaged, 1/6-octave response in MF's listening room as set up by MF (blue) and by MBL's Jeremy Bryan (red), and of Wilson Audio MAXX 3 (green).
Davey's Speakers:
Fig.12 Sonus Faber Guarneri, room-averaged 1/3-octaveresponse (top, solid, 5dB/vertical div.), electrical impedance magnitude(bottom, dashed, 2 ohms/vertical div.). Minimum value is 5.8 ohms at 260Hz.
And your point is?
I noted that in my opinion MBL's have the best sounding high end. How they measure is of little concern in this crazy hobby of ours.
If I'm looking at the measurements for Davey's speakers correctly, it looks like his tweeter response nosedives a little beyond 10kHz. Is that because the tweeter was designed that way or does it have a tendency to ring so it was rolled off before it could get itself into trouble?
They would certainly be missing out because Maggie's are some of the best sounding speakers made.
Absolutely Bruce!. But i know for a fact they will not send samples to Stereophile because of the measurements.
Nope, and never said I did. I'm just commenting on what the FR graphs show which is a tweeter that rolls off above 4kHz. Based on the measurements, I would expect these speakers to sound very warm due to the rolled off highs. Pair them with a tube amp like the D-70 MKII, and one should be able to wallow in the midrange warmth. No wonder Davey is very susceptible to hearing the Focal tweeters ringing. His own speakers are very rolled off in the highs and anything that has extension beyond what he is currently hearing with his setup will stand out like a sore thumb to him.
What I consider unfair is judging someone's system without hearing it. He did not just comment on the speakers, which would have been fine, but on the entire system.
Can you invalidate his assumptions? They are no off-base IMHO.
I did hear Steve systems in numerous occasions and with different amplifiers ( ARC 600, 18-watts/ch Lamm and current top of the line LAMM) I never heard ringing. I have heard the X-2 with Spectral gear and didn't hear the ringing. Such ringing was by the way to my ears apparent with the WP7 , 6 and 5, I don't know what tweeter they use. I haven't heard the XLF yet
Excellent thought about the subs as I tend to agree. The way they are set and crossed over results in only subtle changes but sufficient for some visceral impact
Have you tried positioning the subs as per Amir's topic a while back, i.e. mid-front and mid-back walls or mid-side walls facing into the room?
(...) These tubes are not only perfectly matched with the same S/N but also have never been used
These will be rolled into my ML3 amplifier later today
I was tweaking the laser lights in my room yesterday and caught some R2R bling.....
Steve,
Next time you should request non-tested sealed tubes. Can you imagine the feeling of disturbing all these electrons that have been resting for decades in the cathodes?
