We always, in order, consider: Room - Loudspeaker - Amplifier. Loudspeaker for the Room and Amplifier for the Loudspeaker.
+1We always, in order, consider: Room - Loudspeaker - Amplifier. Loudspeaker for the Room and Amplifier for the Loudspeaker.
Properly designed equipment should have adequate internal regulation ,and be correctly grounded .
Vibration islation under turntables can be worthwhile.
Nothing is perfectly designed at consumer-level products.
Well if you say so then it must be true, regardless of the collective experience of many others including some highly educated engineers. I would kindly suggest making such observational opinions in a manner that declares them to be "in your experience" rather than as being statements of absolute fact.Solid state equipment will gain no benefit whatsoever .
Keith.
Clean Power, proper grounding is paramount too as is vibration control.
This is turning out to be a really interesting, thought provoking thread.
My finding Zu was such a serendipitous moment, they sold themselves to me in 5 minutes in 2008, and 7 years later I've never regretted my decision for a moment.
A big plus point has been the ability, nay insistence, for the Zus to make me go SETs, and the combination w/a whole series of system of tweaks is to die for.
And now, w/my second set of Zus and second set of SETs, I'm at a sort of epiphany moment, where I really want for nothing (not saying impvts can't further be wrought)
And so my paradigm has been to stick w/high efficiency/SETs, since this seems to be the "flavour" or "personality" I like.
Hence my choices being - stay as is/go Zu Experiences (soon to be released $30k flagships)/go horns eg AG Duos, Trios or Sadurnis/all sticking w/my Nats SETs as is.
But Audio Land's paradigm really chimes w/me too. Assess the room you're in and what spkrs it will support and won't support. Pick the best one within budget. Find the amps that suit that spkr the best.
No middle way between these two paradigms.
Agree with the statement, clean power is the foundation of feeding electronics. The cleanest we have found is using a dedicate own power to power the room: Generator Set. It is to much hassle but you won't be living without it after installing and hearing the different.
What kind of generator you found that was acceptable for your purpose? Many of them will introduce mechanical noise into the lines.
david
Hi David,
No noise at all when you put it on the other room. Ultra silent 53db at 7 meter.
We cracked the wall since the door was too narrow for it. Forklift will be needed unless you have 17 strong friends who can lift this 1700 lbs godzilla.
Hi have you heard both the trios with bass horns and the sadurniWish you all the best in finding the right one for your room. If your room can accommodate AG duo, trio and Sadurni, we are just speculating here since we have not compared them in our room, Sadurni will be likely a better choice.
Happy hunting!!
Its the speakers and the amp and the room
I went all in and bought the G1's and a devialet and then rebuilt my room to suit the combo
I could write reams on what the system sounds like etc .. but suffice it to say that every time you listen , its not just music , its an experience.
So, in a nutshell, am I right to consider amps-spkrs synergy/pairing as a whole, or still go for the best sounding spkrs, and adjust the amps choice accordingly?
I think this is a false dichotomy. I think one selects the speakers one wants (going for "the best sounding speakers") and then one selects an amplifier which, to one's ears, is synergistic with the speakers ("amplifiers/speakers synergy/pairing as a whole") which, together with the speakers, creates the sound one wants.
I think this is a false dichotomy. I think one selects the speakers one wants (going for "the best sounding speakers") and then one selects an amplifier which, to one's ears, is synergistic with the speakers ("amplifiers/speakers synergy/pairing as a whole") and which, together with the speakers, creates the sound one wants.
Heard Sadurni at the show only. As with Trio, our customer has Trio with bass horn. We are familiar with electronics for the Trio since we have supplied some amps and cables for him. Again, we have not compared them side by side.Hi have you heard both the trios with bass horns and the sadurni
