Thanks for that response, Myles. Agreed, you are never going to eliminate ALL distortion, but there appears to be almost a magical barrier in terms of lowering the distortion to a certain point, that you CAN get through. One can think of it almost like the sound barrier (pun intended!) that engineers were working against for years: many technical people gave up, believing it was impossible to go faster than the speed of sound, it was a pretty fanatical few who kept persevering and persevering, and suddenly it happened. Then everyone accepted that is was possible, and everyone moved forward ...
For me, as I have repeated over and over again, the key is treble disortion. The ear/brain is most sensitive to this, the higher the frequency the worse it is, and virtually all equipment is most prone to producing it -- nature really had it in for us!! I can't say how much you have to reduce it by, but I do know you have to be absolutely meticulous in eliminating weaknesses in your system to reduce it to the right level. In this regard, all connections are a big headache, for example!
How do you know you have it low enough? By the fact that you can no longer hear the tweeter working! Many of the people here now think I am totally mad, because I keep banging on about this, but once you experience it, you say, "Bloody hell!!"
Why do you hear the tweeter working normally? I believe it's because your ear/brain is having to work hard to bypass, listen past the high frequency distortion, to hear the intended message, the musical performance; so the ear/brain focuses like crazy on that sound source to pick up what it wants to hear. It's a bit like listening to a person talking in a noisy room and trying to catch the words-- you stare rigidly at his mouth almost, hoping to pick up the words.
Frank
It seems to me that what you're talking about [distortion] has more to do with long term "listenability" than it has to do with "big" sound.
And for me, that problematic area for distortion doesn't lie in the upper octaves but in the upper midrange area, specifically around 3000 Hz. Thats why you have trouble eliminating it because you're searching in the wrong area. Indeed, if you read the papers by Jung, Marsh and Curl, they'll point out what we often interpret as FR aberrations is actually distortion.
Give a listen to a system based around a set of well designed set of electrostatics; that'll give you a clue about some vanishingly low distortion levels.
Actually, it has to do with both. When it falls into place, everything works correctly. You can listen for hours for hours on end, AND it will give you the "big" sound. You know whatIt seems to me that what you're talking about [distortion] has more to do with long term "listenability" than it has to do with "big" sound.
Yes, and that is exactly what Vince has, who is using the same language as me. Yes, they are not ya standard Quads (which I have listened to recently, driven by the "proper", current Quad valve amps, etc. -- pleasant enough, and a good starting point to start tweaking), but the primary means of producing sound is very similar, and he has only achieved the "trick" by fiddling with his gear for 6 years. As he says, he is sick of hearing people say that they know what his system sounds like ...Give a listen to a system based around a set of well designed set of electrostatics; that'll give you a clue about some vanishingly low distortion levels.
Thank you, Vince, and perfect timing!!Exactly, and among all the Apogees that were made, the Scinitlla is a champ at revealing a system's devils.
frank - 1, mep - 0
Frank
Frank
Actually, I am looking in exactly the right area! The distortion that we wish to eliminate are the harmonics, etc, of that 3kHz tone which are 6kHz, 9kHz, 12kHz, 16kHz, 18kHz, my goodness, high frequency stuff! And where do you hear that high frequency stuff? Why, out of the tweeter of course. No wonder tweeters sound so "dirty" so much of the time ....And for me, that problematic area for distortion doesn't lie in the upper octaves but in the upper midrange area, specifically around 3000 Hz. Thats why you have trouble eliminating it because you're searching in the wrong area. Indeed, if you read the papers by Jung, Marsh and Curl, they'll point out what we often interpret as FR aberrations is actually distortion.
Okay, mep, I get your point.
The distortion at 9.53kHz has to be reduced to a level of 0.0034%
The distortion at 12.7kHz has to be reduced to a level of 0.017%
The distortion at 16.85kHz has to be reduced to a level of 0.009%
These are very firm figures I have figured out over many years using my $200K worth of test gear, and need to be followed precisely ...
Happy now?
Frank
I'm sorry, mep, unfortunately you're wrong. The Status Quo is excellent at pinpointing whether the amp is reasonable or not, 10 years ago most amps were pretty atrocious in this regard, the latest ones are getting better, Naim know a thing or two about it, class D done PROPERLY will do it nicely, as Vince knows. Every time you read a review where they say the sound changes depending upon volume you know the amp is not up to snuff.Since any modern amp is not producing distortion at a level you would ever hear from a tweeter unless you are clipping the amp
You said before on another post that you removed the tweeter cap
No, it doesn't. Many people with well sorted out systems will say that: they can turn up the volume quite a bit and you not really aware that it is getting louder.The sound will always change as you turn up the volume.
That's another urban myth. When working well, I can turn down the volume, and turn it down until you can barely hear it, and the sound is still there. My wife, says, "You have to turn it off completely, otherwise my head keeps being drawn to the music, when I need to be concentrating on something else." THAT'S the down side: when working well, you can't ignore it, I'm afraid.Every recording needs a certain volume level in order to sound realistic.
On one amp did the hardwiring thing, and boosted the power supply caps with decent ones in parallel, ended up throwing out the big Mutha caps it used because the screw tops were turning (another weakness!). It still has weaknesses though ...So if you seriously think that the amp is causing the tweeter to distort, please explain what methods you have used inside the amplifier to banish these distortions.
Jack (or anyone else who knows)-where do you draw the line between a small room and a large room? My room is an "L" shape that is approximately 15' W x 23' L x 9' H. The L shape is at the listening end of the room and adds an additional 4' of space to the left of where I sit. I wouldn't consider this to be a small room, but I don't know if it qualifies for a "large" designation either. Who set the definitions and what are they?
I have never said I removed a tweeter cap, just that it would be a smart thing to do if you could filter the signal or protect the tweeter by other means. Frank
Sorry, mep, my fault, I was just being sarcastic in the sense that tweakers get very upset by supposedly low quality cap's, I should have added an icon, as inSo, I guess I deduced that since you called the cap "useless" that you removed it.
Thanks, Vince, that's a good clarification. There would be no point in having a flute solo blowing the windows out, I take your point ...One place where Mep is making sense is, when you tune in an acoustic guitar solo, there will be a proper volume.
