Andre, multi-channel?
Honestly I highly doubt it. I really know very little about Multi Channel and I have not once seen that request on their forum.
And one of the reasons I am a Roon customer is that they listen. Folks wanted Bryston support, now they will get it.
I had run into it in their forums while I was searching for other things. Just looked up and here it is: https://community.roonlabs.com/t/roon-through-a-bryston-bdp-1/4145/6where did you see requests for Bryston integration?
I just did a search on Bryston's own forum and there are mentions there too: http://support.bryston.com/forum/viewtopic.php?f=44&t=238
"I’ve started experimenting with Roon, software from RoonLabs to manage, listen and experience your music files. From the first minute I started the software on my desktop pc I knew that this was it. The software makes you discover your music-database in a way you couldn't imagine before.
After some playing around I was able to use my BDP-1 as a playback device using 'shareplay'. In the beginning it was not behaving very stable and playback was sometimes breaking up. Once I rebooted everything, I disabled all services I did not need on the bdp1. Now only 'shairplay' is running as a service on the bdp1. And it works great!
This is the software that should be running on the bdp1 itself! And, sorry Bryston, but it will take ages before the mpd-software can do what Roon does."
Anyway, what is the reason for asking? I now know the founder of Roon and my chief designer knows the CEO (?) of Bryston so if there is a reason to know, I can maybe go and find out although I doubt they would want to say anything public until they have a working system.
Yes, I understood that RoonSpeaker was what the hardware folks will implement. Although I do admit that I do sometimes find the Roon architecture confusing.What hardware manufacturers will implement is RoonSpeakers, *not* Roon itself (or Roon Core as they sometimes call it). This is just the playback/streaming part of Roon, not the library/UI part of it. The *next* step is for Roon to port RoonCore to the different NAS platforms, so we can be rid of computers completely!
There *is* a cost involved for the hardware manufacturers who want to implement Roon(Speakers), as they need to actually implement into their software. Roon has eased a lot of this by providing code for manufacturers (not only Bryston, it's open to everybody), but there's still work to be done on the manufacturer side, of course. But as Amir said, the R&D cost of integrating Roon is offset by the fact you're supporting an up and coming technology. Same thing happened with Tidal. Those that were at the forefront of Tidal integration, like Auralic, reaped benefits, no doubt.
Now, come to think of it, since the Bryston units probably have enough computational power, they *could* implement the full Roon experience inside the unit... That would be pretty cool too...
Roon takes little CPU resources. If I did not have its display on, I don't know that I could even measure its footprint in the server I just built. That said, the hardware needs to be fast enough so that when it gets busy managing the other things it is already doing in the NAS, that it doesn't cause Roon to fall behind and cause an audible glitch.Interesting notion about the "full Roon experience" on a BDP-2..or an Aurender or what ever...but I doubt they have the horsepower..the beauty of these machines is that travel light and they have but one task, bit perfect file playback. But as I said..the market will determine the end result.
The Bryston has an Intel Atom CPU, which is the same as on most NAS units, like the QNAP! It surely has enough capacity to run RoonCore, specially since all the UI work will be done by another device (computer or tablet on the network).
I don't know what the Aurender units have for a CPU, but it's possible it's something in that same league!
There are quite a number of enhancements planned for the Radio function, including playing Tidal content that has not been added to your library. At the current moment I suspect the primary focus is on RAAT (RoonReady) and RoonSpeakers.
Some snippets from the Room Community on the Radio function:
https://community.roonlabs.com/t/whats-radio-and-how-does-it-work/164
https://community.roonlabs.com/t/understanding-radio-functionality/4195/3
https://community.roonlabs.com/t/what-is-the-expected-behavior-of-radio-for-all-albums/1500
Sorry for the late reply. Did not see this before. Audio data rates are very slow compared to HDD speed so I expect traffic to be negligible. Ditto if your are using gigabit Ethernet.CPU is only 1 resource, how about NIC and HDD?
It is a big barrier. I suspect a lot of that expense is for the rich metadata license that comes for a lifetime that way. We paid millions of dollars per year for metadata licensing when I was at Microsoft! There is very little competition out there and so there is not much room for negotiation specially when you are a small company like Roon.Also, sounds to be a very well thought out app, the gate to market adoption is the cost. $400+ is a lot of scratch when competitors comparatively are <15% or free....
Thanks Barr! I'm loving Roon. I am on the trial. My only worry about becoming an Roony forever is Tidal. If Tidal fails, then Roon is Doom. I hope more tidal finds its way into the radio. It's a natural fit.
Tidal is failing badly in Australia
Constant dropouts, long buffering - it's almost useless
