Steve-As you know I own the EMU 0404 DAC. I'm using mine with USB from my computer/server. I am not happy with the sound, but I don't know if it's because of the USB connection or the DAC just isn't that good or its just me and my aversion to digital. I bought an interface cable so that I can take the S/PDIF signal that is lurking on my MB and feed the S/PDIF signal to the EMU and see if that makes any difference. The jury seems to be out as to whether it will make any difference or sound better or worse based on some comments I received on another thread. The cable should show up next week and I will give it a try. I would like to sort this out as I don't think my digital should be so far in the weeds in comparision to my analog rigs. I know that you liked the sound of the EMU that Larry brought to your house. Until I get this sorted out (assuming I ever do), I personally wouldn't recommend the DAC until the time comes to put it on Audiogon and extoll its virtues.
Mark, have you considered not using the included SMPS but something better? Here's a very, very expensive ( ) option for you to try:
http://www.mouser.com/ProductDetail...EpiMZZMtd%2b2RMOh0Ly67MVk98F9Ec9KGWAYV%2bMI4=
Thanks. That is a good list. But I must say, I got a chuckle reading about the company who is selling them:
"We use the following criteria for distribution on our web site:
The components in the electronics must exceed US military specifications"
"We are the # 1 importer of Chinese Audio in the USA"
Something tells me Chinese Audio companies are not trying to comply with US mil spec . And at any rate, I am confident there are a ton of components that not mil-spec. But we digress.....
When Larry brought his EMU to my house, I thought it sounded pretty good for the price.
HD2 doesn't impress me (uses USB power and such).
HD20 seems nicer but the web site lacks detail on the implementation.
Gary-Never thought about that. Have you tried it with good results? $30 isn't much to spend if you think it will make a noticeable difference.
Hi Mark - the improvement is significantly more than $30
I've even used it with expensive gear with great results.... and you don't have to do very much. Cut the SMPS off the existing lead you have on the piece of gear, and screw down the binding posts. B&K also makes bigger ones that are even better. The $30 one is a good start though.
Just found this new Peachtree Dac: http://signalpathint.com/index.php/iDAC/iDac.html
Doesn't have async USB but the ESS DAC claims to get low jitter without it. We will see . I will see if I can get my hands on one to evaluate. Searching online, seems like no one has yet reviewed it..... $999.
Amir, I may be able to help you. I can get you in touch with David Solomon at Peachtee.
