i know how you feel, but rest easy i went from gold to these NCF and tone was not adversely affected. its just better right out the box. its not bright, its not weird in the top end. just clean but not sterile. i dont know about going from what you have but i would think it will be less affecting than where i came from. so dont worry.
for me bass was the biggest improvement with no down sides elsewhere .
its not jaw dropping, just a little better.. you will get used to it and forget you done it in no time, just like every other tweak. its worth it imo.
Good to hear ! What were you using prior to the NCF ?I have 350 hours on my GTX NCF -R . Awesome. Bass deep and strong smooth tops organic midrange. No downside whatsoever. I was not prepared for this great an improvement.
my dealer is now almost done switching in these 7 sets of FI-50 male and IEC plugs.
Guys- Not sure if this has been answered- My system has the Equi-tech wall panel with earth grounding rods- I am about to install the Furutech NFC outlets and someone mentioned
that when I install them that I SHOULD NOT hook up the ground wires to the Furutech outlets- He said that it will reduce the noise floor - Does this make sense not to hook up the ground wire??= thanks
thats what I thought and will def. have them grounded- thks
I prefer them mounted with the ground pin up, like the lettering on it suggests. The reason is that they hold much better since they're a little soft to start with.
my Furutech NFC outlets are definitely grounded to my Equi=tech 10WQ wall panel (which has it's own dedicated grounding rod).
quiet as a tomb. super dynamic.
Hi Mike,
Are you using a standard ground rod or a chemical filled electrode?
david
