Dear Ron,
Thanks for questions,
Technically I mean suspensions which have very close resonant points as then we risk they will to excite each other.
Practically this means if two suspensions "feel" equally stiff, stacking them can lead to random results. Yes, rubber on rubber
would be sth I would avoid.
"Mechanical diode" - please lets forget about this audio marketing concept and not comeback to it
Yes, yes, yes, AND YES! NO WAY one can achieve a high bandwith decoupling/damping with just a single technique! Its impossible by the laws of physics. For example, to efficiently decouple ultra low freq. (subsonic) one needs some sort of a soft spring, something that can move. But as the frequency of the vi ration grows this spring will not be able to move so fast and will start passing vibrations through its body (skin modes). So you need another technique to overtake the job where the spring starts to be more and more transparent. Please remember about that when you see some butcher-type of a block or ceramic balls claiming audio vibration control
Your example is something I would do myself, but spikes are not vibration decoupling nor damping. They decouple in some directions and couple in other with a random effect when comes to vibration control. They are great for leveling though and this is how they were invented before audio
My own mastodont rack is on spikes (on the pic I posted somewhere you'll see wide feet as at that time I was experimenting with them) then followed by pneumatic suspension.
I'd rather put it on top to damp eventual resonances in the platform itself. And I can only say go by ear: try different materials critically listening each time to find an appropriate one. BTW, 1kHz active is a simply great achievement from a purely technical point of view so bravo to Herzan/Table Stable! From the audio point of view, this is where we start entering the region of the highest ear sensitivity (see Fletcher-Munson curves).
Thank you for bringing this point! Nowhere I said that. We haven't compared yet our platform to active one so I cannot claim anything.
I said that unlike lab platforms, ours are from the beginning designed for audio and we take care of the behavior in the full audio spectrum
with critical listening at each single step. We actually see ourselves as cheaper alternatives for active platforms (we are priced slightly above
passive labs platforms but definitely below active ones), offering high bandwith, 6 DOF control achieved with different techniques.
Again a very big YES to constrained layer damping (CLD)!! This is a very well known, widely used engineering technique and I would not anchor it to any commercial company, no matter what their marketing specialists say
BTW, we rely for certain tasks on CLD too. But CLD is an art: you have to find the right mix of the viscoelastic plus constraining layer for a given application.
1) What would be examples of stacking similar stiffness suspensions?
Does this mean not placing a component with rubber feet on a table top which itself has rubber feet on which it sits on a rack?
Does it mean not using several mechanical "diode" grounding components in a vertical system? (For example, a table top on cones (Tiptoes) where the points face down to mechanically connect the corners of the table top to the top of the legs of a rack, and where the rack itself is on spikes to "ground" the whole system to a concrete slab?)
2) Do you believe vibration control techniques should be mixed, meaning, for example, having a heavy, solid rack the feet of which are spikes, but then having Sorbothane or some other vibration-absorbing material between the top of the rack and the table top which sits on the top of the rack?
3) The active isolation Herzan claims to work up to 1,000 Hz. Herzan suggests using a visco-elastic layer below the active isolation platform to handle vibrations above 1,000 Hz. (This remains extremely puzzling to me because I always thought there should never be any squishy rubber-type material below the active isolation platform.)
4) I am still not clear on why your product is better for audio components than an active isolation platform like Herzan.
5) What do you think of sophisticated rack and shelf systems such as Critical Mass Systems or Harmonic Resolution Systems whose products utilize, among other techniques, constrained damping layer shelves to reduce vibration by coverting vibrations into heat?
