My company is a dealer for SurgeX and I know the company principals so I don't need his help on anything. I am instead asking him to explain what filtering he thinks the device is doing that is relevant to audio.Loan him the equipment necessary and explain how to make the measurement you want.
He doesn't believe in either. The noise he believes in can't be heard as noise, nor measured! Indeed, noise is now being used as the explanation of any subjective improvement regardless of it makes any sense from engineering or scientific way. Every tweak seemingly reduces noise and the cycle can continue to infinity!
You and I consider that nonsense of course but that is the position Folsom, etc. take.
Oops, I forgot to add Amir to my ignore list... done.
(... ) Noise isn't related to what comes out of the speakers when nothing is playing. Noise CHANGES the music itself. (...)
We are in full agreement Yuri.Amir, If only one tool (ears, as example) involved to estimation of result, there probability of error is increased. I always try check one result by several ways.
Measurement tools is easier and faster way of interference cancellation, than ear control.
When we try improve noise floor of system by electrical hum (subject of this topic) need look for especial harmonics and strange signals at spectrum rather than total noise level even.
I know how work electronic systems enough, practically worked with cancellation interference in past times and don't observe there any esotheric.
Yep!
Better to ignore if one cannot answer the questions asked.... with facts.
Surely - but you are addressing subjective noise, as we perceive it, but remember some technically oriented people will not accept such broad definition.
IMHO most of the time power lines and conditioner performance is related mainly to electrical noise - at less it is the only way to understand the effect of the last (or first, depending on perspective, as referred by the Shunyata people) six feet of power cable and connectors in audio systems.
High-end audio systems and mains distribution systems have many variables and we can not have an universal receipt for the best way of carrying power to a system. Anecdotal evidence from members will be mostly circumstantial - although some rules can be suggested for particular situations as Caelin Gabriel did in post #2 http://www.whatsbestforum.com/showthread.php?22740-Dedicated-powerlines-how-many&p=441904&viewfull=1#post441904 - IMHO the best answer to the OP.
Injecting noise into an AC line is tricky business so I am confident as useful as this can be, it is not a test you have run.Well perhaps these people should inject noise into their AC at all the frequencies from 1 to 10,000,000,000 to cover all the bases, and write down subjective results for a better understanding; and note any anomalies electrically. Any technical person can understand just how much noise can find it's way into equipment through many paths.
Everyone here knows what tapping on the wall sounds like. No one here knows what the noise you are talking about sounds like. That is the problem. You have taken a term, noise, which has proper meaning to both engineers and lay people, and bastardize it to mean any subject thing you perceive it to be. Worse yet, you then proceed to recommend remedies such as filtering which are for the classic and proper use of the term noise.I have to ask, did you assume talking about noise meant noises like someone tapping on the wall? Because the answer to that is no, no one's talking about that. It's all electrical, even if it was somehow induced by vibrations.
There's no point when the person who just antagonistically asks questions to be antagonistic doesn't understand facts from engineering and assumes everything is untested theory.
... It's all electrical, even if it was somehow induced by vibrations.
Actually, Folsom, I postulate that you have it bass ackwards.![]()
It's all mechanical energy (vibrations), including those of an electrical nature.
There is no assurance of clean AC lines in our homes. As such any high-performance audio system would take care of the noise that impacts its performance to limits of its specifications. It is of no need of a handful of filter components external to it in another box. I know I will shoot an engineer who charged me $10,000 for an amp or DAC and expects me to then put yet another box outside of it to help it do what it says it does! The filtering in the audio device is application specific and as such can be far more effective. For example I can band limit an amplifier so that it doesn't care about high frequencies. That is a heck of a lot easier to do on a low level input signal than 15 amp, 120 volt AC mains.
for us to understand that every last component design is an incomplete design and it's up to us to complete it. With superior line conditioners and superior forms of vibration mgmt.
I totally agree. I like to think that my equipment is well constructed and top shelf but it wasn't until I put each component on a rack designed to solve the vibration issue that I can say I truly heard my equipment. Same for line conditioners
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
