MSB Select II arrival
jep123
293
106
908
Norway
thanks JP.
what I would be interested in would be if you are considering adding the Ethernet card to your CH C1? I've heard that is preferred with CH C1 users who have compared.
Hi Mike.
Yes, I will probably do that later on. A good idea is to send the unit back to CH when I am on holiday, I hate to be without music when I am at home :).
Rgds
JP
nc42acc
609
40
165
North Carolina
Funny how aesthetics play such an important role in our purchasing decisions. I guess one persons lump of coal is another's diamond.....
Funny, for me the looks of MSB is what I like least about them. Performance has almost always been good though and the Sel2 ...though expensive is top shelf.
wisnon
3,536
640
1,200
Very true, but I dont over-emphasize aesthetics in making audio purchase decisions.
SQ is more important.
Odyssey
24
Very true, but I dont over-emphasize aesthertics in making audio purchase décisions.
Yes, we do "listen with our eyes" first. But SQ trumps all other considerations IMO.
Priaptor
929
19
FL
just noticed the MSB Select II is arriving today, a day early.......;)
Congrats. Mine did as well. It comes much better packed than previous MSB DACs. Nice metal Pelican type cases securing the DAC and power supply. The DAC and power supply are both in velvet pouches for. Nice touch.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
the eagle.....has landed.
at noon i'll run home, unpack it and plug it in. then the SGM team can tweak the set-ups remotely while I'm back at work.
Priaptor
929
19
FL
Congrats Mike. Curious what USB cable you are using?
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
for now, i'll use the 'powered' version of the Sablon Elite I used on the Aqua. I also have a Totaldac on hand to try.
not sure if the Select II needs a powered USB. I know the unpowered version is better if it works with your dac.
you know which USB cable you need now with the Select ll Mike ;)
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
I deserve that :rolleyes: as it's hard to make a case for not going wacko on a USB cable after my decision on the Select II.
all that said, until I choose between USB/SPDIF and Ethernet the cable choice is besides the point. and there are expensive network cables just like expensive USB cables. going nuts on one of those will be a bridge i'll cross when I get to it.
I would bet you that if you were to try that USB cable you just might forget Ethernet and renderers
Legolas
1,048
399
455
France
Can't imagine the Select needs powered USB. It is really for budget 200 USD DACs or external drives, or budget USB input boards in lower end DACs. The power is noisy and hideous, a real nasty problem in USB.
Can you feed it via Ethernet? I would also try AES as non upsampled from the SGM. I believe the Select is the first MSB DAC to not upsample and thus can have no filter.
I bought a 'budget' Audioquest Ethernet cable last week and it is great, CAT7 spec, better than the basic CAT6 I got with my Rednet. It is all about noise and RF rejection with Ethernet cables. I am not sure if it is necessary to go too crazy, I would try sub 200 USD CAT7 cables.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
Steve, that would be one approach I could take, but then I would bypass what I think to be an important question of the whole digital front end design. which I want to figure out objectively.
so respectfully; upgrading those cables now is not the path I'm taking. not that I don't respect what cable performance can do. and I realize that my perception of differences will be influenced by cables. I just have to do the best I can with it.
the Select II I've purchased has XLR outputs, but they will also send me the RCA output module, so I will be able to compare them directly. once done i'll optimize that cable run.....likely with my choice of interconnects, the Tara Labs Grandmaster Evolution w/HFX grounding. I love how that cable sounds with the grounding (working with my Tripoint Troy Signature) and the air tube dialectic.
when I get the digital interface issue behind me i'll deal with the question of cable upgrades for that.
will I even think about a 5-figure list price USB cable? hard to imagine I would but time will tell.
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
the Select II is said to be optimal with Ethernet. i'll investigate that for myself.
I have to ask MSB about the 'powered' USB question, just have not got around to it.
MSB is about to release a new Ethernet renderer which will do Roon and MQA, maybe in 30 days or so. they will send me one to compare directly to the USB interface. so in the meantime i'll be using USB with the SGM server.
I know there are some great Ethernet cables, and that using optical cables for network cables can also be optimal.
Reactions: Kakarella
still-one
1,633
150
1,220
Milford, Michigan
Elberoth
2,011
259
1,170
Poland
I much prefer ethernet as a connection.
It all depends on a particular application.
Mike: have you bought the DAC without listening it first in your system ?
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
Correct. Heard it three times at shows
never heard the Trinity dac, even at a show, but loved it. which does not make it the right move, or wrong move.
Believe High Fidelity
[Industry Expert]
Nov 19, 2015
1,666
321
355
Hutto TX
ibelieveinhifi.com
I would say congrats, but you ordered yours in black when then have an iron man version that would be a perfect match to the dartzeels. You had your one chance and blew it Mike...
j/k
Congrats now we can have that showdown. Dont sell the Aqua just yet :)
Mike Lavigne
Apr 25, 2010
12,602
11,695
4,410
j/k
I've got my quota of red and gold. black is the new black.:rolleyes:
and.....bring it on!!!
and I hope that happens.
the Aqua Formula and La Diva are now officially for sale.
