I just installed it. Coming from network board version 325...I'll post more in a few hours
I think the network card change would have more of a change in sonics vs. the 2.02 update
Thats good to hear....
I'm using 350 and 2.01.
What is everyone using for settings on roon?
Mine:
DXD
Resync delay 1000ms
Most of the resolution changes when in shuffle seem to be gone
I had the Vivaldi DAC (v2.01) today in my system for the whole ... 60 minutes
I have connected the Vivaldi DAC via USB to the Aurender W20.
What I have noted vs my Lampizator Golden Gate (the original version, without the superclocks or the new USB board) is that the vivaldi:
- offeres more see-through transparency;
- has more resolution;
- has vastly improved bass articulation (GG bass sounds bloated in comparison);
- has a bit less 'meat on the bones', sounding a bit leaner and less palpable.
I liked what I've heard. The differences between the two are quite stark and easy to tell. They are also consitent from PCM to DSD. I need to borrow one from the distributor for a little longer.
I have pretty much all Roon signal processing disabled and leverage upsampler to convert all PCM to DXD and pass through DSD or DSDx2 source material to DAC unchanged
I did reduce Resync to 1000ms after update....much improved. I am also installing ROCK enabled NUC tomorrow to take my study iMac out of the path as it now currently is the core. Looking forward to seeing how that changes things
very, very interesting. Which do you prefer? If you can keep only one...which one would it be? And is it a fairly easy decision...or is it a 'photo finish' race?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
