bonzo75
Greetings!
In my own experience, the Micro Seiki SX 8000 and the Artisan Fidelity Technics Sp10Mk3 NGS each in use and by nature remain entirely different yet beastly animals, but fortunately both excel in the art of record playback. Talk about apples and oranges, this is a lengthy topic requiring someone with far more articulate writing skills than I possess to provide you with an adequate explanation.
Beginning with the Micro, which is a champion of majesty, scale, air, subtlety, refinement, articulation, quietness and immense depth + width of soundstage. Whereas the Sp10Mk3 NGS emanates life sized projection of recording scale, width + height, solidity, focus, pitch perfect speed, neutrality, superlative channel separation capability, palpable macro dynamic contrasts, sheer see through transparency with silent backgrounds yet remains very refined as well. Both decks are accurate, erring towards the musical neutral, balanced side of the spectrum to a degree in character, with the direct drive sounding a bit more dynamic and the Micro a tad more relaxed in comparison. Naturally, each design differs not only through different drive propulsion systems and engineering methodology read: belt drive & air bearing vs. direct drive & conventional oil sump bearing but also with dissimilar internal base material composition. When it comes to sheer mass, the Micro setup tips the scales at about 292lbs. with all ancillary components (if memory serves?) and the AF Mk3 NGS in the area of 239lbs., both extremely heavy and exquisitely built pieces. Best to find the right room location and setup one time only!
Both instruments are brutally revealing in nature, imo especially the AF NGS, it will react immediately to any minuscule change to setup, it hides nothing on the recording or within the tonearm and phono cartridge relationship, so if after setting up you hear anything that sounds
off per se, better double check every single parameter carefully for proper connections, alignment & calibration and be sure everything else in the system is up to snuff. To immediately hear the synergy and tiny nuances existing between arms and various carts without coloration, imo this is the ideal model to use for comparing.
Let me have a little rest first and get back to you about some tonearms....
