If people are going to use the UDP-20X for audio they should be buying the 205. It is going to sound better than a modded 203.
Is that based on any experience or just speculation?
Based on reviews of the 2 units, the differences between the units with respect to the audio section and how Oppo has been offering 2 different units for years, one always targeting a higher end audio crowd.
The last “upgrade” to the 203 I have planned is an incoming Kanex HDMI de-embedder so that I can obtain full resolution audio from movie soundtracks (spdif is restricted to 16/48 2 channel PCM output due to Hollywood restrictions). Not sure how much of a difference that’s going to make as everything sounds pretty spectacular right now but for ~$30 used it’s not much of a gamble.
So, given that I'm still blown away by the Oppo's performance since the power delivery upgrade, I decided to go all in on the Kanex HDMI de-embedder as I've also now bought it a linear power supply to really see if it makes a difference without wondering about the harm the wall wart standard SPS the Kanex comes with is doing.
One final question is do I need to care about the HDMI cable from the Oppo to the Kanex (video is being handled seperately via another HDMI cable from Oppo directly to TV) and if so, what's a decent option within reason price wise? I'm currently planning on using this HDMI cable:
https://www.amazon.com/gp/aw/d/B01N343SBS/ref=ox_sc_act_image_1?smid=A2REBULWX98LHD&psc=1
This is a really good thread on HDMI cables.
http://www.avsforum.com/forum/168-h...-support-4k-60hz-4-4-4-chroma-deep-color.html
They are discussing HDMI cables that don't choke with 4K pictures, 4:4:4, 60fps, Dolby Vision ... Video.
I don't recall the emphasis on the Audio equation. ...Like from strictly high res music listening.
You are not going to see a lot of discussion on that because HDMI is the noisiest of the digital routes for audio. Coaxial, optical and USB are all preferred. I don’ think many of the high (or even low) end DACs have HDMI capabilities.
100% agree. I prefer the analog connections myself, but 4K/8K HDMI 2.1 provides easy and simple multichannel digital access to digital bass management and digital room equalization for high res audio music listening in stereo and up to twenty-four channels.
You cannot do that with analog, digital optical and coaxial, and USB.
Why can’t you do that with analog? The 203 and 205 both have 7.1 analog outs. If you have a processor which can take analog inputs that would be the way to go. Maybe I am misunderstanding what is trying to be accomplished.
https://www.amazon.com/gp/aw/d/B01N3...LWX98LHD&psc=1
1. You don't have access to digital bass management and digital room EQ from using the analog 7.1-channel connection.
2. No Dolby Atmos, no DTS:X, no Auro-3D.
3. The OP is asking about quality HDMI Audio cable.
