SET amp owners thread
spiritofmusic
14,626
5,435
1,278
E. England
Ked, I guess he saw your signature and thought YOU were the spammer. And moved past.
Kcin
662
846
275
Canada
The mighty Wyetech 211. It dwarfs the ESLs right next to it. It actually drives the ESLs in such a wonderful way as well.
heihei
469
543
283
Hi,
I heard the L50 in my system for quite a while as well as the General’s system. It is a really great linestage. Actually might be my favourite solid state linestage. It was however drastically outclassed by the Mayer 10Y hence my acquisition of the latter.
CH Precision L1 with an X1 power supply will better the Mayer 10Y, but at a considerably higher price. The bare L1 is a fairer comparison, and as such is a case of different, rather than better / worse. The Mayer has a great flow to the music, with stunning tonality, whilst the L1 has a slightly wider soundstage, a bit more detail and bass precision. With the X1 it gives you the best of both.
christoph
4,689
4,077
825
Principality of Liechtenstein
Which of the many 10Y versions are you comparing?
Reactions: Audiophile Bill
Tango
4,938
6,269
950
Bangkok
...then Tang thinks his Ayon sounds a lot better than the CH. And ddk told Tang Lamm would make his sound go beyond the Ayon. Mike on the other hand trusts that his Dart dusts the Lamm at warp nine. Mr.T has both Dart and Kondo but thinks his Kondo oust the Dart. And Bonzo probably says the Thomas Mayer edges the Kondo. :rolleyes:
Shall we do one more round?
Tang :)
spiritofmusic
14,626
5,435
1,278
E. England
Tang, don't you mean one more around and around?
Audiophile Bill
4,293
4,093
675
There are several versions of 10Y Heihei.
bonzo75
22,650
13,685
2,710
London
I think a lot of things better Kondo, though I did find the m1000 sounding better than Lamm at the late Detlof's. From hei hei's perspective, a clean SS amp like CH, Soulution, Dart, will sound better than active valvey stuff or a full bodied class A sound like vitus or FM pre with the Berning quadratures
Reactions: gian60
bonzo75
22,650
13,685
2,710
London
Also Gian prefers CH to Kondo so we are back to where we started. This is like groundhog day
audio.bill
550
90
340
Chicago suburbs
What's the feeling regarding SET designs implemented with only a single output tube, compared to so many SETs using multiple output tubes in parallel to provide more power? Seems intuitive that running multiple tubes in parallel eliminates some of the simplicity and purity that a single tube output would offer, but I'd be interested in hearing other opinions in this regard. TIA and happy new year to all!
Tango
4,938
6,269
950
Bangkok
bonzo75
22,650
13,685
2,710
London
What power are you looking at? KR va 200 is the best high powered such amp I have heard, and it is multiple valves. But then you have to make sure they stay in sync over time. Jack will probably tell you the same
CGabriel
618
92
265
WA, USA
www.shunyata.com
Several years ago I was looking for a great “low power” tube amp. I had heard the Ayon amps at many international shows and in every case they performed superbly. So I asked Gerhardt Hirt, owner of Ayon, this question: “If power level is not a consideration, which amp has the best purity of their amplifiers?”. He recommended the Crossfire which has a single output tube (per channel). I have had many amplifiers in house and the Crossfire is still our favorite (with all the caveats. Within power limit and amplifier to speaker synergy).
And then some amplifiers with multiple output tubes can be run with some of the tubes unplugged. Check with the manufacturer on this.
bonzo75
22,650
13,685
2,710
London
Hang on, didn't you have an issue with not turning this into an SS v Tube thread, seems like you are doing just that LOL.
Seriously? They are doing specific pre compares not a general can SS do better than tubes or vice versa where Mike is voted out as the bad guy
4,704
Simplicity yes, but why purity? Unless they are very mismatched the curves of a composite tube are as "pure" as those of a single tube. However, putting tubes in parallel will lower the output impedance of the device, increasing the damping factor considerably. This will surely affect the sound attributes of the amplifier.
Lamm and conrad johnson, among many others, use composite triodes using many triode sections in parallel - up to 10 in the ART preamplfier - in their top preamplfier model. I never heard that this affects the "purity" of their designs.
christoph
4,689
4,077
825
But unlike groundhog day, here is no correct solution, only personal preferences ;)
christoph
4,689
4,077
825
