Unfortunately, no. The fly in the ointment is the consistent (variable) magnitude of the energy field the component sits in. The mechanical energy produced by loudspeakers permeates into the component and your right back where you started from. You would hear a gradual sonic drift back to the original state of equilibrium.
So, lets's say you have a component chassis that has been knocked off of neutral by the manufacturer. There is 1 component I can think of made with a double bottom separated by a teflon buffer with a nylon pole connecting the top plate to the bottom. The manufacturer uses a proprietary foot that benefits from the teflon liner and the pole. I've never tried it, but my guess is that upon inserting CS2 in place of the proprietary feet, you would hear the teflon/nylon pulling the sound field in an unpleasant direction. In this example, removing the CS2 feet would return the component to its original state of equilibrium and that would be a good thing provided my suspicions were correct.
It works both ways.
Ok, the mechanical behaviour of the system will be affected. Anyway after the settling period the feet could be removed and reinstalled since S(n)>S(n-1), the disorder never diminishes.
