Center Stage2 LS Footer designed by Critical Mass Systems for VSA
Damon Von Schweikert
WBF Technical Expert
Sep 15, 2016
99
205
140
California
www.vonschweikert.com
Engineered by Critical Mass Systems, the Center Stage2 “LS” Series loudspeaker foot is an unparalleled breakthrough in cabinet resonance mitigation; the culmination in years of experimentation and development based on the groundbreaking and award-winning Center Stage2 footer technology. No matter how good your system is, the Center Stage2 “LS” Series loudspeaker foot will add a new dimension to your listening experience, making any system sound better.
The “LS” series foot dramatically reduces distortion through improved resonance control which allows you to experience far greater accuracy to the original recording across the entire frequency spectrum by lowering the noise floor of your system. Musical instruments and vocals will emerge from the blackest of backgrounds. And the higher your system’s resolution, the greater your results will be from this revolutionary resonance mitigation technology. Nothing less than total immersion.
In addition to the promised sonic improvements, the LS Footers are designed for ease of use. Each LS Footer incorporates a telescoping shaft which allows you to level your loudspeakers once installed. Simply rotate the bottom disc to raise or lower the LS Footer while mounted under the speaker to achieve a level setting.
Depending on the size of your loudspeakers, we offer three different sizes of footers as listed below.
LS 0.8 with Titanium adapter $650/ea. MSRP
Specifications
Surface Mount Diameter: 38mm/1.5”
Recommended Maximum Weight: 91 Kilos/200 lbs. or less*
LS 1.0 with Titanium adapter $950/ea. MSRP
Specifications
Surface Mount Diameter: 60mm/2 3/8”
Recommended Maximum Weight: 363 Kilos/800 lbs. or less*
LS 1.5 with Titanium adapter $1,250/ea. MSRP
Specifications
Surface Mount Diameter: 76mm/3”
*4 feet recommended per loudspeaker cabinet
For ultimate performance, we recommend four footers per loudspeaker. The entire top surface of the footer must be in contact with the bottom of your speaker for optimum isolation and resonance mitigation. To this end, we offer three mounting options to accommodate any loudspeaker.
Simply Place Directly Under Your Speakers
This is by far the easiest mounting solution and is 100% effective in isolating your loudspeakers while eliminating cabinet resonances delivering the lowest distortion possible.
Threaded Adapters
Included in the price of each footer is a threaded titanium adapter manufactured to fit your loudspeaker’s specifications. This mounting option offers an increased level of safety and security for your loudspeakers and is highly recommended for those benefits.
Custom Outriggers
Should you desire, our hardware design and manufacturing team will fabricate custom airplane aluminum outriggers for your loudspeakers that offer an attractive aesthetic while providing the same level of sonic performance as if the LS Footers were mounting directly to the bottom of your speakers. Please contact us for price quote.
gleeds
424
594
180
Really nice update Damon. Easy and effective - what could be better! The outriggers look great too.
