A dream come through; Airtangent Reference sn35/100 pictures
It all makes a difference in the sound. My friend ended up with a compressor and tank so he had ripple free flow or his AT. :)
I know
50 feet of airhose works better than a tank....
I have friends with Forsells and ET etc and they have tanks as well
best
Leif
The Airtangent Reference titan linear tracker tonearm sn 34/100 is landed :)
New Old Stock in original alloy box.
Complete with a Micro Seiki SX 8000 MKII custom tonearm base
(as this base goes on 2 corners, it does unfortunately do not fit my TechDAS)
May be I will speak to Hideaki Nishikawa in Munich, if they can develop and produce a matching Tonarme base for my AF3P turntable.
concrats and welcome to very exclusive club
only 100 of theese were produced
more pics pls?
magnesium or carbon armtube?
did you get extra moving assys?
remember to install pump unit BELOW arm, to avoid potential condensation running DOWN into arm-assy
best
Leif
more pics pls?
best
Leif
I am not sure which armtube, but I would say, that it feels like the Magnesium version.
The arm was bought from a German Customer, who never fitted the tonearm,
so it is a unit from the original German distributor "Audio Components"
It will take some time, before I am going to fit the arm, as I need a matching tonearm base first.
Next weekend I will start to read the manual in detail :)
definitively magnesium...
s/n before mine :cool:
pretty easy to set up....
if you don´t already have, buy som spare Norgren filters
best
Leif
Shakti - that is awesome.
I have mounted one on a airforce 3 works well, superb tonearm one of the finest ever produced, can we see a picture of the control/regulator chassis and the compressor. Leif was constantly changing things there were many versions of the Reference and the 10b.
great,
do you have pictures of the Tonarme base? Was ist done from techDAS?
I will do some pictures from control/regulator chassis and the compressor, they never left the alloy box.
You do always find some rare pieces Jürgen. What cartridge are you planning on using with the arm ?
Reactions: bonzo75
cartridge is not yet clear. May be I will try my Air Tight PC-1.
Reactions: Lagonda
It´s not a std unit...it´s a cavity in the chassis he adresses and also some customizing in the internal driver x/o
he knows his way around....
