422a sucks I hBe told you guys many tines lol let us knowThis one...
Daily ACME, when i want to treat myself i plug in WE274b engraved base or WE422A...to expensive for daily casual listening with kids
Pm me I’ll explain its simpleI don't know what your problem is. I asked a legitimate question and all you want to do is fight. Al's comment seemed to indicate you can't measure amperage just using the tube pins. He states that clearly unless I misunderstood. I have no idea what a wind up is but why would I be trying to set up you up? We are just having a discussion about it.
Don't bother responding. I will figure this out elsewhere.
Buy a cheap SS recti it’s good to have it is great for burning in output tubes It also gives the best detailed bass periodI haven't tried the Tak in the Pacific yet. It was my preferred rectifier in the Big 7 but this could be different. I will report back.
Now upper freq not always good. But for background music or non crital is great as recti burn full playing or not
Lol to some hahaha but a ss recti and postOh, I have a box of 5U4Gs and other cheaper rectifiers. I also have CV378s, GZ34s, etc.
Is the 596 considered cheap?
Good to hear! Things OK here as well.Norman, doing well. Trying to avoid boredom mostly these days! Music always helps.
Marty
And don’t listen to anyone who says you measure amps putting leads across the pins.
The leads go in series one lead to tube pin not inserted
The send lead hues into tube socket where the pin is not being used. I can’t send a pic for now.
if you have leads and alligator you can use the to connect or faster
But you really don’t need to know amps just dc voltage
Wow even I understood thathttps://www.bbc.co.uk/bitesize/guides/zsfgr82/revision/3
Good diagrams.
My explanation was not good. Measure the voltage (not the current) across the two filament pins i.e. in parallel, and if you get 4V for PX25, say, since V=IR, for a given filament resistance which is fixed and which you need not know, you must have the right current.
Agreed Al?
Yes agreehttps://www.bbc.co.uk/bitesize/guides/zsfgr82/revision/3
Good diagrams.
Agreed Al?
On Aug 11 you said “I just did the same with an Osram PX25 and got 1.8A on average.” Doesn’t sound like it was a lot time since you made this measurement. You also told me it was “child’s play.” You even told me how to set up my DMM to measure amps. It wasn’t a formula applied to voltage.
Measuring voltage across the filament pins is pretty simple.
dminches - I think you have AD1n to UX4. So obviously use the UX4 300B pin out diagram you posted for the filament pins to use i.e. the two thick ones as we discussed.
Everything should now be ultra clear and yes I do apologise.
One being a socket saver adaptor
Then it gets opened to expose wires
Great now remove the tiny pin holding it in place. Now you can spread the top from bottom. Find a wire that connects thick pin from bottom to top. cut the wire. Now Use both leads as before on amps. place one lead on the bottom wire and the second lead to the other side leading to the top cut wire. Now you have a series circuit to use to measure Amps.
